Thread: HEATING PROBLEM
    San antonio 210
    Exclamation HEATING PROBLEM
    I cant get my heater to work right. It blows out simi hot air. the temp guage would go up slow and take longer to heat the motor . as i would drive i would hit the brakes and the temp would drop but never over heat. 95 altima
    IA Member donek9's Avatar
    cochran, GA
    thermostat maybe?
    Oct 2003
    ^^ That's the only thing that came to mind. Swap it out. Be careful because on the Altimas, they have bleeder screw under the distributor so be certain to purge the air out first before you start it up or you'll blow a head gasket.
    San antonio 210
    thanks fellas
    correct thermostat and bleed it out with the bleeder and leaving radiator cap off until all bubbles completely stops while doing so turn the heater on high
    yeah
    recommend some tv shows
