Thread: obd0 to obd1 wiring help
    1989 honda civic dx 4wslude's Avatar
    at a jack in a box
    Default obd0 to obd1 wiring help
    i need help i got the obd0 to obd1 ecu harness and i am having trouble at the dizzy i got 5 wires on the obd0 engine harness and the obd1 dizzy has 7 i am missing the blue/green and the blue/yellow i have a 1989 honda civic dx duelpoint and have a d16z6 intake and injectors and have a d15b7 obd1 dizzy all the other wires match up on the dizzy but i dont have the to others i need will be on here alot trying to figure out the problem
    you have to add a the sensor at the dizzy, add the two injectors as well as move a few pins around on the ecu. Also you have to invert tps.
    at a jack in a box
    i got the injectors wired and the tps wires swaped i think i found the problem i have to swap two pins on the ecu to add the tw wires im missing
    at a jack in a box
    and i didnt know i would have to swap pins with the obd0 to obd1 ecu harness i bought
    yes because they are assuming you have already done the dual point to multipoint
    at a jack in a box
    still nothing how much would yall charge to fix it i have everything swaped just keeps on spinning over its getting spark
    F.O.C.U.S jdmshytyo87's Avatar
    Oct 2009
    cedar bluff, al
    just get a multiprt harness and re pin the ecu or get a jumper harness...
    at a jack in a box
    new update got spark but the injectors are clicking so its no getting fuel
