Thread: Pulley Wabble!!!!
    Get off my back bitchesss
    Default Pulley Wabble!!!!
    Ok i posted a thread on here not to long ago with a crank pulley problem. well all it was the bolt was loose i tighten the bolt and everything was fine! But now its make a claking noise. i have no clue what it is and how to fix it! Now its sitting in my driveway and i need help fast its my only transportation besides my motorcycle but its way to cold.. Should i replace the motor and be done with it or should i replace the pulley... what to doooo???? please help.. thanks.
    ps: its on a 1994 Aucra Integra LS motor.
    cleveland,tenn
    probably when it was loose it ate the inside of the hole out so, u probably just need to replace the crank pulley
    J.R
    Down South
    humm..... i don't see how the pulley would be damaged
    Dahlonega
    1. unscrew bolt
    2. remove pulley
    3. inspect pulley and crankshaft
    4. inspect keyway and key
    5. take pictures
    6. report back
    ^ ok thanks
    05srt4
    Jun 2009
    Upatoi, Georgia, United States
    its probably ur keyway on the pulley or crank. on my b20, i have the same problem but i cant fix it until i research good enough to find out what bearings will work with a ls crank
