Thread: Valves stuck open on my D15B8, any ideas as to why?
    Oct 2009
    Warner Robins, GA
    Default Valves stuck open on my D15B8, any ideas as to why?
    So i pulled my head today because I had a leaking head gasket and am about to change it out. when I pulled the head, I found two valves that were stuck open, all others were closed. The exhaust valve from the #2 cylinder and the intake valve from the #3 cylinder. Should these two valves be open like that? If not, whats the cause of it? keep in mind, before I pulled the head I placed the #1 piston at TDC ( honda manual said to) and this is an 8 valve D15B8 head. I also had oil all over my spark plugs when I pulled them as well but im thinking that may be from needing new spark plug tube seals. not 100% about that though. Please help, i need to get this thing back on the road, my truck kills me in gas!!! thanks for any help in advance!
    did you take the cam out?
    Southside Ridin HATCH
    If you didnt take the cam out then THATS WHY! haha
    your moms house
    yo clear your pms
    (((((No more 4 door))))))
    Oct 2009
    Warner Robins, GA
    so if my cam is still in, those 2 and only those 2 valves will be open? because all the rest are flat and the #1 cylinder is at TDC which would mean my cam gear is in the UP position. Just making sure, I dont know s**t about single overhead engines
    aye bro .:Stirfry:.'s Avatar
    bc the lobe is pushing the valve open
    ATL DAsquad Member #9
    325is NJSC's Avatar
    Dec 2009
    Buford
    Quote Originally Posted by r.etheridge View Post
    Dude you are in over your head.
    that's how I roll
    Oct 2009
    Warner Robins, GA
    Quote Originally Posted by .:Stirfry:. View Post
    I understand now. I mean i understood before just havent messed with a single cam 8 valve set up before like this D15B8. Ive never really messed with a D series before so im kinda learning as I go. Im going to rotate the cam and make sure they go back in so I know for a fact they are not stuck open. I posted a previous thread to this one about a funny noise (sounded like a valve to me) coming from the head. I just wanna make sure thats not the issue I was hearing.
    Oct 2009
    Warner Robins, GA
    Quote Originally Posted by NJSC View Post
    wow, thats real helpful....... and no, im not. Just never messed with a D15B8 head. very different from any other heads ive messed with. If you dont have any info to offer on this thread, then dont post on it
    i gotcha man. if the noise was a funny ticking sounds they just probably needed to be adjusted. but if you need any help just PM me bc i live in warner robins too.
    Oct 2009
    Warner Robins, GA
    I PMed u
