Results 1 to 15 of 15
Thread: h2b ef?? details...
    cleveland,tenn
    Exclamation h2b ef?? details...
    need to know what all is needed to do it besides
    motor
    tranny (using a b16 tranny)
    h2b kit (probably qsd)
    b series mounts
    shift linkage
    axles
    what wiring harness can i use. (car is converted to obd1)
    also does anyone have pic's of where u have to beat the frame in on the driver side (also is there anywhere else u have to beat it in at?
    and who makes the adapter plate to use a d series alt.
    any help will be thanked
    and since its sometimes hard to find a cable b16 tranny
    use the wiring harness thats in the car now
    u need to beat it where the crank pulley sits
    esp, explicit speed performance, for the alt bracket
    center field
    it would be better to cut and reweld where the pully is
    LAWRENCEVILLE
    Quote Originally Posted by dirk-diggler View Post
    Hell no thats the frame rail he is talking about!
    Hella stock member!
    center field
    Quote Originally Posted by silversol View Post
    have u ever done this swap ?
    LAWRENCEVILLE
    I have done tons of swaps in my day. as well body work cutting and rewelding a frame rail is serious work and is not for a novice! They are more likely to do serious structrial damage cutting and rewelding a frame rail that holds the suspension and the shock tower above it.
    Hella stock member!
    center field
    it is a lot to this swap many dont know . it well wroth cutin and reweldin . im not saying chop it in half, u need to take a inch out , and if you are a novice u need to pay a pro to weld it
    cleveland,tenn
    yes just finished one in a buddys teg but wanting to know if there is any diff in doin it in a ef. and no...... im not cutting and rewelding the frame..... rather beat it with a hammer lol.....
    center field
    yeah dependin on what mounts u use the intake mani hits the master cyclinder and there is no room . and if u dont beat in enuff of the frame u will be pullin out the motor a coulple of times till u get it rite
    cleveland,tenn
    we pulled the h2b out 7 times before we got it beat in far enough, and which mounts will clear it? u would think it would clear the brake master cyclinder. remember its in a ef there is no clutch master cyclinder but u maybe rite. also i would probably use a stock intake manifold for now
    cleveland,tenn
    ok just saw what u ment but on qsb's website. there is a crx which has a stock manifold ( atleast looks like it) but it does seem close. and cant tell which mounts he is using
    center field
    Quote Originally Posted by 0\s accord View Post
    i am rite i have done this swap 2 times in a ef
    cleveland,tenn
    ok than what mounts and intake manifold did u use? i didnt say u were wrong i was just trying to see what u were saying from more than one source?
    center field
    evo mount kit and skunk manifold
    cleveland,tenn
    have u heard of any other mounts that will work? cause i dont want to use the evo h2b fit. i was looking at hasport or drop engineering.
