Results 1 to 4 of 4
Thread: da dash removal?
    Kennesaw, GA
    Default da dash removal?
    how do you take out the dash. any idea?
    aye bro .:Stirfry:.'s Avatar
    there is really like only 5 bolts holding it in.
    first
    - take out all your plastic panel like the kick panels
    - glove box/ just to get it out of the way
    - radio and its cover and the center console
    - the cluster bezel. be careful not to break it
    - then take out the cluster, be sure to unplug the speedo cable first makes things a lot easier.
    - the the steering wheel.
    - THE MAIN PART EVERYONE FORGETS, TAKE OUT THE CLOCK IN THE CENTER OF THE DASH. BC THEIRS A SINGLE 10MM BOLT HOLDS IT THAT YOU HAVE TO REMOVE.
    - disconnect all yours electrical plugs.
    - now on the side of the dash theres remove both covers on the driver side and passenger side, its held in by a plastic screw.
    - and there should be two 12mm bolts on each side if i recall.
    hope this helps. since im not using any pictures. lol
    ATL DAsquad Member #9
    oh yea your gunna need to take the 4 bolts holding in the steering column and drop it bc its gunna be a pain in the ass tryna take it out.
    and also i remember theres also a single bolt on the center near the bottom down where the radio is
    Kennesaw, GA
    thanks for the help/info. working on it this weekend let you know if anything.
