Results 1 to 10 of 10
Thread: question for a champion.
    Champ
    Feb 2010
    Warner Robins GA
    Default question for a champion.
    Alright. I have a 95 Gsr that I put a b20 vtec in. It was running fine just effed up idle so I got on here and saw someone put a post with the same issue. The post said to tighten the screw in the fast idle valve. I did that and it fixed it. Idles perfect now. The issue is I did that at about 10:30am on the 30th and I went and test drove it. Everythin was great vtec hit all the goods. I went to sleep woke up messed around at the house and left for work at 9:10pm on the 30th. Now for some reason my vtec wont hit. No cels and now im at work. When I got here I checked the oil the its perfect. Im going to check the vtec screen when I get off around 9 in the morning. My question obviously is, is there anythin I should check to figure this out. I can't believe I have no cels and its not hitting. Thanks to anybody with a reasonable answer.
    Champ
    Feb 2010
    Warner Robins GA
    Bump bump bump.
    J.R
    Down South
    check the obvious, make sure you didn't damage any wires while messing with the idle screw? No cels is weired, what ecu
    Champ
    Feb 2010
    Warner Robins GA
    Didn't damage anythig man. Sorry p72 gsrrr ecu. Yup crazy no codes perfect idle idk. It was throwin a code 43 I put a new o2 and and it went away (for the drive to work) when I get off it might butme back on. Hope not but it probably will. Any other ideas?
    you got a clogged oil filter or vtec screen, if changing/cleaning both does not fix the problem replace the vtec solenoid
    Champ
    Feb 2010
    Warner Robins GA
    Ight im gonna check today. I have another Gsr vtec solenoid.
    J.R
    Down South
    if not wiring i would do this ,if nothing swap v tec solenoid
    check for codes anyways, just because the light isn't on doesn't mean you don't have a code in the system.
    My line of work
    www.internationaljets.com
    center field
    does your cel work ...lol check all wireing for vtec,
    Champ
    Feb 2010
    Warner Robins GA
    Alright guys finally got some free time today before work. Took soleniod off and of course it had some shit on the screen. I took the top Peice of and tried to push down on the spring/circle piece and it was jammed so I swapped them and it worked for about 5 minutes on my way to work. I think what happened was when I sand blasted my vc I didn't get all the plastic media out from the underside even though I did wash the shit out of it. Anyways thanks for the help this is my last work day of the week so im gonna change to oil and oil filter and see if I can un cloge one of these and get it to stay working lol thanks again for the input!
