Thread: gsr lags at 3k picks back up when floor boarded
    IA Member b13isme's Avatar
    Oct 2008
    rome
    Default gsr lags at 3k picks back up when floor boarded
    0bd2 gsr
    problem Lags or skips at 3k-3.5k ish gains power when floor boarded
    all cylinders are getting fire
    New Distributor,spark plug wires, spark plugs, and head gasket
    check engine light by autozone only says misfire cylinders 1,2,3,4
    I'm thinking map sensor
    96 Gsr
    Hm, cylinder misfire in Cylinders 1,2,3,4. you think its MAP sensor. Hm...... Eh..
    Is your firing order right?
    flatside up it should be
    3 4
    1 2
    cylinder nearest crank pulley being 1
    Oct 2008
    rome
    I mean I havent touched my motor(besides to check oil level) since about 4k miles ago when I replaced Distributor,spark plug wires, spark plugs, and head gasket so i don't think so but ill double check. theres two sensors attached to the throttle body think its the one faceing toward the firewall
    96 Gsr
    J.R
    Down South
    Check timing with timing light, is idle ok
    LAWRENCEVILLE
    If it has a miss fire on all 4cyl I would check the crank sensor and wireing its very common when people do timing belt jobs on these they dont tuck the wires back where they should be and the wires rub the alternator belt anf will throw a code for a miss fire on all 4 cyls
    Hella stock member!
    South Side Georgia
    Check your fuel pressure.
    resize pic
    J.R
    Down South
    Quote Originally Posted by silversol View Post
    Learn something everyday
    Oct 2008
    rome
    since my car has the service port i didnt know it had the handy black and brown wires for you to jump together so im sad to say i just found several codes
    6- Coolant temperature sensor or circuit
    23- knock sensor
    41- Oxygen sensor heater ( Integra), front oxygen sensor heater
    47- Fuel pump
    73- Misfire, cylinder no. 3
    Honestly where should i start... money is a problem right now and its a obd2 acura at that
    96 Gsr
    check connections to coolant sensor (below distributor, single 1 wire plug), ignore knock.. it wont kill you, change o2, change fuel pump & fuel filter, and open dizzy and check/clean internals.
