Results 1 to 23 of 23
Thread: B18B1 very high Idle at start and intermittent idle after driving??
    IA Member Sylent Nite's Avatar
    Question B18B1 very high Idle at start and intermittent idle after driving??
    Title says it all. I acquired a 1994 DB8 with a B18B1 in it. On cold start up the car Idles around 2,000 RPM. After running for a bit it will go down to around 8 to 900, but at a stop it surges sometimes between 900 to as high as 1600 or so. At first I thought it was a vacuum leak but i'm not sure at this point. Any help would be great. Thanks
    AccuracyPerformanceAutomotive
    May be the IACV is starting to go bad. Any codes?
    500whp of spinnin fury!!!
    None that i am aware of, previous owner may have unplugged the CEL though, Ill go and plug my scanner to it and check and see if its throwing anything.
    Cycle the key and see if the cel comes on then goes off after about 1 second. And a 94 cant be scanned, you"ll have to jump the scs connector. Count the blinking lights. lol
    Ha yea your right. My scanner only does OBD2, lol. But no the CEL doesnt cycle at all which means he had to have unplugged it. Guess in my lunch break I will go and pull the cluster and plug it back in, now I gotta see if I can remember how to do the jumper to count the flashes,. lol
    Yeah people pull the bulb to sell the cars. Hahahaha. 1 long flash is 10 and a short flash is 1. So 2 longs and 3 short would be code 23.
    Cool, code 23 im assuming is for the IAC valve? I know thats a common issue with B series motors too. Thanks for the input so far also Catch!
    Not a problem. 23 was just an example. I think 14 is for the IACV.
    Certified Gearhead Rsporty's Avatar
    Douglasville, Ga.
    Quote Originally Posted by CaTcH22 View Post
    IACV is 14 or 15.
    I'd remove the IACV and spray it out real good with some carb cleaner.
    Don't forget to check the fast idle valve, on the bottom of the throttle body, too. It has a plastic "retainer" that comes unscrewed over time.
    Just remove the cover plate (2 screws hold it on) and you'll see the retainer. It's a round plastic piece with a hole in the middle and a slot in each side. Use a flat head screwdriver or something similar to screw it back down, all the way, till it stops.
    Unless it's a vaccuum leak, these two are usually the culprit and both are easy fixes. Takes about 15 minutes to do each.
    Just call me DAD!
    Nice, I did notice a line going into the throttle body on the front side held with 2 screws, looked like it had some coolant coming out of it. Like a slow leak or something. Ill def. check those both out when I go on break. Thanks for the input guys its really appreciated.
    J.R
    Down South
    iac is code 10 i belive one long blink, thats what it sounds like
    F.O.C.U.S jdmshytyo87's Avatar
    Oct 2009
    cedar bluff, al
    OBD1
    Code Meaning
    1 O2A - Oxygen sensor #1
    2 O2B - Oxygen sensor #2
    3 MAP - manifold absolute pressure sensor
    4 CKP - crank position sensor
    5 MAP - manifold absolute pressure sensor
    6 ECT - water temperature sensor
    7 TPS - throttle position sensor
    8 TDC - top dead centre sensor
    9 CYP - cylinder sensor
    10 IAT - intake air temperature sensor
    12 EGR - exhaust gas recirculation lift valve
    13 BARO - atmospheric pressure sensor
    14 IAC (EACV) - idle air control valve
    15 Ignition output signal
    16 Fuel injectors
    17 VSS - speed sensor
    19 Automatic transmission lockup control valve
    20 Electrical load detector
    21 VTEC spool solenoid valve
    22 VTEC pressure valve
    23 Knock sensor
    30 Automatic transmission A signal
    31 Automatic transmission B signal
    41 Primary oxygen sensor heater
    43 Fuel supply system
    45 Fuel system too rich or lean
    48 LAF - lean air fuel sensor
    54 CKF - crank fluctuation sensor
    58 TDC sensor #2
    61 Primary oxygen sensor
    63 Secondary oxygen sensor
    65 Secondary oxygen sensor heater
    J.R
    Down South
    [QUOTE=jdmshytyo87;39158700]OBD1
    Code Meaning
    SCORE
    Oct 2009
    cedar bluff, al
    thought that might help out a lil bit...later...
    Ok, so I pulled the code today, sure enough the doucher had the bulb out of the CEL light. It gives me 4 long pulses and a quick 5th pulse. Anyone know what that is?? Not seeing it on the list above. Thanks
    (EDIT) It just hit me thats code 41, lol Sprry been a while since I pulled OBD1 codes so bare with me, lol. So thats being said its the 41 Primary oxygen sensor heater???? Exactly WTF i that, lol
    Southern Speed
    Macon
    that shouldnt cause it to idle like that. Check your intake manifold gasket also. Get some carb spray or brake cleaner and spray along where the intake manifold meets the head, if you hear the idle change pitch then you know you need to replace the gasket.
    you may have a possible vaacoom leak, find that leak danny san!
    Douglasville, Ga.
    I don't think the O2 sensor is causing your idle problem.
    Might just need that, TOO.
    Did you clean the IACV and check the fast idle valve, like I said?
    Also, try spraying carb/injector cleaner on the vaccuum lines and listening for idle surges.
    Just call me DAD!
    Jul 2009
    Anniston, AL
    take some carb cleaner and spray it close to the corner of the intake manifold on the drivers side....same thing was happening to my car i replaced everything and it turned out to be a vac leak on the underside corner of the intake manifold...if it surges when u spray it replace the gasket..but to start easy make sure ur tb gaskets good
    Certified Gearhead deondre's Avatar
    Jun 2010
    im 100% sure its your FITV.its under your TB. 3 10mm bolts takes it off. unscrew the 2 philips screws on the backside of the FITV and then screw the valve down inside of the FITV ( dont over tighten). plug everything back up and i guarantee it will stop your idling from beingso high on start up, and it will not surge. had to do it to 3 of my b18 motors....takes about 20 mins tops!
    WTB 16x7 Polished Slips
    Douglasville, Ga.
    Quote Originally Posted by deondre View Post
    Hmmm.
    Sound familiar?
    Just call me DAD!
    Senior Member EJdm's Avatar
    Wow I'm also having this problem n my 90 teg but rev a little higher on col n hot... Gotta try some of these stuff tomorrow...
    "Arriving at one goal is the starting point to another." – John Dewey
    Kennesaw, GA
    Quote Originally Posted by EJdm View Post
    x2
