Results 1 to 11 of 11
Thread: LS starting problem
    IA Member DomHenry's Avatar
    Sep 2010
    Molena, GA
    Question LS starting problem
    Hey i have a 91 CRX with a 91 LS swap, and the issue is im not getting any spark.. i went and bought a brand new dizzy and still nothing. I plugged a spark tester into one of the wires and i didnt see a blue spark. I dont think its the battery because its only about a month and a half old. any help or points in the correct direction would be appreciated
    JDM-AZ-FUK
    aye bro .:Stirfry:.'s Avatar
    there are many things to check. the main ground on the harness, main relay etc
    ATL DAsquad Member #9
    Jun 2009
    You need to know if the battery has juice or not first. Do the accessories work with the key turned?
    Sep 2010
    Molena, GA
    yes the battery has juice and all that.. like when i turn the key it makes some wierd noise but i can see cam gears turning but the turn slow
    JDM-AZ-FUK
    Jun 2009
    Google "advanced ignition troubleshooting"
    Sep 2010
    Molena, GA
    alright thanks
    JDM-AZ-FUK
    um, do you have a CRX SI?
    Sep 2010
    Molena, GA
    yea i have an Si, and i dont think the distributer could be the problem cuz i went through 2 of them then i just bought a brand new one a few weeks ago and it still does the same thing... and another thing i forgot to add is the intruments dont light up but the headlights and tail lights come on..
    JDM-AZ-FUK
    IA Member DA9_JDM's Avatar
    Nov 2010
    austell
    maebe is out of time
    check your grounds. all else fails i can come by and get that thing running if you throw me some loot
    Sep 2010
    Molena, GA
    alright ill check them.... pm me your charge rate RBS and that might be an option
    JDM-AZ-FUK
