Results 1 to 23 of 23
Thread: questions for anyone that has done a j swap
    revolution big mac's Avatar
    Default questions for anyone that has done a j swap
    im just trying to get a list of everything i am going to need and things i will need to do.
    i know i will need
    motor and trans
    custom engine harness
    mounts
    shifter box and cables
    ecu
    axels
    am i missing anything?
    and just trying to get anytip from people that have done it alread before i start
    Chickens Eat Eggs
    south side hoe
    Custom Fabrication...
    money, duh
    There is fabrication needed. And it's cheaper thank a k. U can do it for like 4k
    everything looks good. the hardest thing is to find the right tranny.
    yeah man. bc the only manuals are 6 speed. i dont think im gonna do it bc i got good dyno numbers today on this setup
    yeah you already have a nice set up. it would still be nice to feel that v6.
    Southside Ridin HATCH
    Quote Originally Posted by laokid View Post
    True.
    Quote Originally Posted by big mac View Post
    Also. just curious whats making you lean towards the J swap? Would you ride with the No hood shit, or get the mounts that make your oil pan 2 inches from the Ground?
    Im sure your H feels damn good..
    accualy i was just getting a dam good deal on a j32a3 but desided to pass it up. i would of rock the first gen mounts and rocked cut hood. just like to give everything a try. my set up made 259whp and 230tq. some im happy with it
    Yea I hear ya...
    Thats some good numbers... I know there is a Thread in here with your setup.. But what all is done to your H.. To get that power? That is on spray correct?
    h22a swap stock bottom end
    h22 type s cams
    skunk 2 cam gears
    skunk 2 intake manifold
    skunk 2 68mm throttle body
    removed balance shaft belt
    aem fuel rail
    dsm 440 cc injectors
    aem fpr
    msd spark plug wires dsm 440 cc injectors
    walbro 255
    3inch velocity stack intake
    kidd racing drag race header
    custom 3inch exhaust only magnaflow resinator
    fluiddyne radiator
    m2b4 tranny lsd stage 3 clutch with 91 accord shift assembly
    zex wet nitrous kit with smart box 65 shot
    all motor it made 199 whp and 156 tq
    Thats cool man.. Like I said before.. Good numbers.. For what it is..
    My buddy made 208hp and 165tq.. Give or take a few.. Tuned at Import Experts..
    ^ stock H22A, with Kidd Header, Skunk2 Mani, 70 mm, Short ram Intake...
    thats good man. im thinking exhaust might be tobig for na but good for the nitrous
    Is it full straight pipe? If not, you might want some back pressure....
    And the full 3 inch.. should be fine.. It wil support more mods with the 2.2 .. and yes the Nitrous
    straight pipe it just has a magnaflow resinator. gonna be doing hondata s3 with a 100 shot to control everything better
    Shit man.. well GL with everything in the future..
    I might be building a H22A, If I dont build another R motor.
    im prob gonna start building a single on boost or a all motor c1. just on the side
    go to www.j32a.com
    there is a lot more to those swaps than meets the eyes. For instance the auto and manual engines have significant differences in the timing belt side of the engine and how the ecu reads cam timing to crank timing. The gears and backing plates are different. Also you need a manual harness and a lot of sensors like one that reads marks on the flywheel also. So my best advice is get a full manual swap that hasn't been broken apart so you get everything.
    My line of work
    www.internationaljets.com
    Jul 2009
    Anniston, AL
    Quote Originally Posted by blown_ss View Post
    if im not mistaken a tranny out of a 2003-2004 accord/tl is what u need to look for
    that or the type s cl which has the lsd
    any 03+ accord will do you. Technically you can use any of them but it sure does complicate things if you use a really new one from a tl.
    My line of work
    BULLL SHIT.
    ^^^You can do the swap for 4k, the fabrication part is that there is none. Just wiring and mounts and then the issue of the hood to deal with.
    My line of work
