- New guy from BAMA!
- Rep Power
- 16
New guy from BAMA!
Hey guys, my name is Chandler. I travel to atl every now and then, and I read on the forum some so I figure Id join up! Im from north AL.
Now for the rides:
2005 Impulse Blue GTO (1 of 39!), M6, factory 18s, Procharger p1sc 6psi, coated headers, no cats, custom cam, springs, pushrods, Monster 4 6puck, 18lb flywheel, Lingenfelter launch control, bmr drag bags, Lowered 1" front and .8" rear. 566whp 497wtq
1988 RX-7 gxl......LS1 block, Diamond dish pistons, K1 rods, stock crank, ARP: rod bolts, main studs, head studs, 317 cast heads lightly ported, polished chambers, custom grind cam, Comp triple springs, comp pushrods, custom front mounted single turbo/intercooler setup, Precision 67/65 BILLET wheel journal bearing, 3in exhaust, th350 full manual valve body, TurboII rear end. Full interior with stereo and sub STREET CAR. 2702lbs.
- You may not post replies
- You may not edit your posts
Forum Rules
