Thread: radiator reservoir over fill
    lawrenceville,ga
    Default radiator reservoir over fill
    i recently did a b20b swap and my radiator reservior gets over fill after i drive car.. and my upper radiator hose shrinks.. i already got all the air out of the cooling system and change the thermostat. also i checked for leaks and nothing.. is it because the upper hose needs to be change or do i need a new radiator idk i need help
    Projects
    Quote Originally Posted by jdm eg6 View Post
    i recently did a b20b swap and my radiator reservior gets over fill after i drive car.. and my upper radiator hose shrinks.. i already got all the air out of the cooling system and change the thermostat. also i check for leaks and nothing.. is it because the upper hose needs to be change or do i need a new radiator idk i need help
    The upper hose shouldn't be shrinking sounds like maybe the Radiator could use a flushing or at worst replacement. Also if its been shrinking the hose you may wanna replace that do from wear and tear of expanding then shrinking.
    aye bro .:Stirfry:.'s Avatar
    get a new cap. the spring in the cap is probably to weak. did you pressure test the cap thats on it now.
    ATL DAsquad Member #9
    lawrenceville,ga
    i replace the upper radiator hose this morning and it keeps doing it.. but either way it need to be replace.. thanks reppss
    lawrenceville,ga
    Quote Originally Posted by .:Stirfry:. View Post
    no i havent tested the cap but that seens to be the problem because is not holding any pressure and it sents the coolant to the reservoir thanks for the help hopefuly thats causing problem
    repps
    yep no prob man.
    Certified Gearhead deondre's Avatar
    Jun 2010
    did you get it fixed yet? im having the exact same problem?!?!
    WTB 16x7 Polished Slips
