Results 1 to 2 of 2
Thread: FS: SS Clutch Release Rod: EVO 8 / 9
    Project ReD dEmOn gtlimer's Avatar
    Where you're not!
    Default FS: SS Clutch Release Rod: EVO 8 / 9
    sold!
    When running clutches like the Exedy Single, Dual, and Triple Clutch Kits. Problems have been known to exist; due to clutch not fully disengaging.
    With this machined clutch extender rod, your clutch will properly work. Save your transmission, and save your synchros.
    Machined from strong 4140 chromium-molybdenum steel (not some weak mild steel from a local hardware store) and built 1/4" shorter than stock, this modified clutch slave cylinder rod will give you a plenty of clutch adjustment range without maxing out.
    A recommended upgrade when replacing or rebuilding the clutch slave cylinder on EVO with heavy clutch kits.
    Fits Lancer Evolution VIII / IX
    Where you're not!
    sold!
