Results 1 to 14 of 14
Thread: INTEGRA TAILLIGHT/CLUSTER FUSE BLOWING!!
    Jan 2010
    We can do business
    Default INTEGRA TAILLIGHT/CLUSTER FUSE BLOWING!!
    ok guys please be mature about this as it has me very frustrated and if you don't have anything helpful or positive to say I'll be glad if you keep your comment.
    my tailight/cluster fuse keeps blowing... I KNOW IT IS BECAUSE A WIRE IS TOUCHING SOMEWHERE!! problem is I cannot find the wire. I have wired and rewired everything possible.... system/radio/etc with no solution. I put in a new fuse and it blows instantly.
    It happened when I chirped from 1st to 2nd one day and I looked down and the fuse just popped. Ever since I cannot find a solution and I am very frustrated... I even got a ticket for it..
    I was told an electrician can follow the fuse back and figure out where and which wire is touching. I don't know if this is true or not but if anyone can help I would greatly appreciate it. If someone here knows how to fix it and fixes the problem I am willing to pay!
    JDM TYTE AnthonyF's Avatar
    A proper mechanic CAN do this. But it tends to be costly b/c wire shorts are generally the most expensive diagnosis procedure due to the tedious labor involved. Find a good shop that can handle this sort of work.
    -Ant.
    The Carbon Fibered R6
    Southside Ridin HATCH
    Or if you have a Test light, ohms meter,Wiring schematic,ect....
    YOU can also do it.
    But yes indeed if F'n sucks to figure these types of problems..
    GL to you.
    northside
    go to mitch
    Jan 2010
    We can do business
    Quote Originally Posted by vtecdude93 View Post
    go to mitch
    who is mitch?
    YOU can also do it.
    GL to you.
    thanks! and yes it does suck i dont drive at night now
    Quote Originally Posted by AnthonyF View Post
    -Ant.
    hmm do you know of any shops?
    I can fix it.
    Jan 2010
    We can do business
    I can fix it.
    how much??
    Certified Gearhead dannysun's Avatar
    rome ga
    it is our cd player in your car bro. the power wire check it
    H22Turbo DC4 from a roll
    Jan 2010
    We can do business
    i checked it a thousand times man lol
    WEST_SIDE
    I do 80% Electrical Diags at work. they are a pain in the ass!!! but a huge satisfaction when u find the issue. anyway man it can get costly specially with shops charging fro 92 bucks an hr and up. specially if u get into flow chart charge. THEN your in for it. but your issue sounds pretty straight forward.
    anyway what i would do is get a schematic and follow where ever there's a junction box/circuit breaker/or connectors.
    for example if the circuit has two connectors first one by the drivers seat second by the trunk. what i would do is disconnect he first connector. Plug a fuse in if it blows you knows it is pass the the first connectorif it doesnt then it is from the that service connector to the fuse box. brkae it down keep it simple.
    another thing u can use is a multimeter. or power probe. look for continuity with ground.
    also if you use this tactic i would disconnect the light bulb im some rare occasion i seen a busted bulb cause this same issue. also bad or corroded pig tails.
    I cant really tell you a price because I havent looked the car over...
    Jan 2010
    We can do business
    okay guys I was messing with some wires and now got it to turn on. 30 minutes later the cluster, park lights, and tailights went off. So my first thought is that the fuse blew again. It didn't. The fuse is now good and does not blow but the cluster, tail and park lights still dont work. any ideas?
    Did you ever get it fixed?
    Electrical Engineering Undergraduate
    Georgia Institute of Technology
    Go Jackets!!!
    barrow county
    this thread is almost 2 1/2 years old
