Results 1 to 13 of 13
Thread: HELP!!!! CAM GEAR JUMPING A TOOTH!!!!!!!!!!!!!
    EAT~SLEEP~VTEC
    Columbus
    Default HELP!!!! CAM GEAR JUMPING A TOOTH!!!!!!!!!!!!!
    ok so basiclly i got a PMR=b16 head w/ b18c block an type r internals. I got it some what built an when we set the timeing an we turn the motor over with a wrench after about a turn an a half the intake side cam will jump a tooth on the timing belt. its the gsr timing belt and nothing in the motor is locking up because without the belt on everything spins freely. also if we rotate the motor in the opposite direction it does the same thing on the exhaust side cam...............PLEASE HELP!!!!!!!!!!!!!!!!!!
    I CANT HELP IT'S FYE
    Northwest Georgia
    look and see if the tensioner moves , see if its in a different position from when you initially tightened it. My timing belt came loose on my race car 3 times during dyno tuning, come to find out my new block has a shitty hole for the timing tensioner bolt that let it tighten down on the tensioner but not enough to keep it in position under a load. To fix i had to add 2 washers to the tensioner bolt to keep the threads from bottoming out.
    EAT~SLEEP~VTEC
    Columbus
    i preciate dat i cheacked the tensioner an its tight as hell and the belt stays tight to the whole time
    Southside Ridin HATCH
    Hmm... Cant be much more than.. The belt beeing a lil loose.. Or the tensioner not doing its job..
    What exact internals are you using? what pistons and cams?
    EAT~SLEEP~VTEC
    Columbus
    idk it doesnt seem like the belt loose AT ALL. cams r crower stage 3 an pistons r ctr
    Wow!..
    You sure your not having some Clearance issues?
    Did you "clay" the motor..
    I just hade basically the same setup, and the clearance is VERY LITTLE!
    EAT~SLEEP~VTEC
    Columbus
    idk i dont think so but im not the expert...... an no i did not clay the motor. yea i kno it has little clearance.
    EAT~SLEEP~VTEC
    Columbus
    i found out wut it wuz the dumb ass mechanic never adjusted the valves when he got it back from the machine shop so they were so far down they were hittin the pistons
    EAT~SLEEP~VTEC
    Columbus
    FUCK ME!!!!!!!!!!!!!!!!!!!!!!!!!! OK SO I FIXED THAT (oh an the valves were fine they werent bent or anything) BUT I RAN IT FOR TWO DAYS AN THE FUCKER JUMPED A TOOTH AGAIN. I think its this damn ebay timing belt i got ima try a gates an see where that gets me. an also the plugs seem to be fialing out???? any suggestions???? cuz my car sounds like a subaru
    THAONLYDAW/SISEATS
    Winder
    dont get a gates either....honda OEM!!!!!!!!!!!!!!!!! might sound stupid but check the 02 sensore as well....and there could be a problem in the dizzy thats y it sounds like a STI
    JDM TYTE AnthonyF's Avatar
    Quote Originally Posted by Cory96EK View Post
    So you spent all this money on an engine, internals, checking the head, etc.... and you run an ebay timing belt? Seriously?
    Gates are great belts, don't let people fool you. That's all I ran on my supercharged mustang. Going OEM is the best way b/c you won't have to question the belt or how many teeth it has.
    -Ant.
    The Carbon Fibered R6
    SOUTHERN SPEED
    macon ga
    i thought gates made honda belts so a gates would be no different them a stock belt ?
    252plus hp and 34.5 miles to the gallon all motor. 12.2 at 111
    Northwest Georgia
    theres nothing wrong with gates, Goodyear gator backs are also very good belts. Hell Ive used a damn DRIVE RIGHT on Rocket motor sports springs and retainers with no issues and those are some STIFF bitches.
