Results 1 to 13 of 13
Thread: BOV Leaking ? HELP
    Mar 2010
    Default BOV Leaking ? HELP
    I have the SSQV HKS from ebay. So its not the name brand BOV. Anyways I have been having a boost leak. So today I did a boost leak test and the only leak I have is my BOV. I asked my cousin about it and he said all BOV leak a little. Is this true ? Can I fix it from leaking ? Will I have to get a new one ? All advise will be helpful, Thanks.
    does your BOV leak when open or closed?
    tUrbo D ... 00CiViC00's Avatar
    mine did it also , just put a new o ring in it
    Norcross
    i sealed mine up with epoxy around the edges lol. kuz my ebay one was leakin a little too.
    Mar 2010
    so do you mean the o-ring that goes in between the front piece that you can screw off and on ?
    new Volvo owner
    Sep 2008
    Woodstock
    Is it leaking at the flange ( where it hooks to the pipe) or from the bov its self? When the car is boosting, the line to the manifold should help keep it closed, also some of those have a set screw to adjust the tightness of the spring. if the flange is leaking, put either a O-ring in or silicone the connection,
    Mar 2010
    Its leaking from bov itself, but I also found out that in the morning when its cold and i first drive my car, the first time I WOT I always build full boost, but then the other times I WOT its like 6-7 psi and full boost is 9.01 psi. What could it be guys ? Does my symptoms sound familiar to any of you ?
    Newnan
    exhaust restriction could cause it if you have a cat clogging
    Running in the DEC
    Nov 2009
    ALL BOV"s do not leak. Try using some quality products.
    http://synapseengineering.com/
    This product will hold 60 psi easy with no leaking.
    warner robins
    JJSPEC.COM
    IA Member demarianx's Avatar
    Aug 2009
    ATL GA Fairburn
    i got the same ebay bov and mine doesn't leak i even but mine on my boss dragster it held 35 psi easily
    96 Volvo 850 T5 turbo
    98 Mustang Sprayed
    06 Dodge Charger
    Jan 2010
    Fayetteville, Georgia
    If I wasn't building full boost, I'd look for a boost leak, which you already seemed to have pointed out.
    Woodstock
    I had the same BOV, the black ring inside where it purges was my issue. The piece that has the ssqv imprinted on it, when it purges the thing gets sideways and sticks causing a leak. But then sometimes when it purges again it'll unstick. Buy a quality BOV and don't worry about it.
