Thread: 95 civic break light not turning off
    JDM-EJ1 shadowx3's Avatar
    G-County
    Default 95 civic break light not turning off
    i have a 95 civic hatchback and for some reason my break lights wont turn off and even when i step on the break they dnt come on they stay on and i cant find the solution to it anyone can help me?
    you should check your relay. trying taking that off first the switch inside of the relay might of went bad and it's stuck on the turn on brakes light like when you operate the brakes..
    No you're wrong.
    Look in your carpet, is there little blue pieces of plastic? Look at the brake pedal and see if the plastic piece came outta the pedal to operate the BOO switch.
    G-County
    whats the boo switch? and i dnt see no plastic on the carpet
    Apr 2010
    look on the top part of your brake pedal, there should be the switch, the reason why its stays on is because the plastic stopper got messed up(classic), u can either go to autoparts and get a pack or get a penny with silicon an glue it there, this will cause the switch to have a stopping point and trigger itself.
    A boo switch is a Brake On Off switch.
    ^^^Yep its the main thing I tell people is to look for plastic in their floorboard, but that is the easiest way to tell. Also easy to replace so GL OP.
    My line of work
    www.internationaljets.com
    Certified Gearhead deondre's Avatar
    Jun 2010
    look at your brake pedal, there is a button behind it, and there should be a piece of plastic in between them. if there isnt, put some washers or a nut in between them. the same thing happend in my integra, and it would kill my battery everytime. i put a nut where the plastic was and viola!
    WTB 16x7 Polished Slips
    Senior Member EG_Ryder's Avatar
    Oct 2009
    Southside ATL
    This just happened to me, the piece that might have broke off would be a little blue rubber(not plastic) grommet with a tip that looks kind of like the tip of a marker. check the floor board under the pedals for it, or check towards the top of the brake pedal for a switch like they said
    IA Member John@TA's Avatar
    Oct 2010
    Paulding County
    the switch itsself can go bad too. I've seen this countless times
    just use a bolt and nut and put it in between the pedal and vIOLaa it'll act like the boo switch .. I was going crazy when it happened to me. can you say EZ fix 8D
    /Oo ___A___ oO\
    |=_/_______\_=|
    Titties!!!
    unplug the lights, classic in georgia to have none anyways. j/k don't do this for real!!! though i do run into(literally almost hit them) many people who neglect that they have no lights at night time.
