Results 1 to 27 of 27
Thread: which TB?
    Jan 2010
    We can do business
    Default which TB?
    okay guys I have around 2 in mind but I am not sure what size will be best for my setup...
    82mm 11.6cr with hopefully pro2 cams...
    i am also debating between the s2p mani or performer x... what do you guys think???
    what brand/size tb and what mani...
    Oct 2009
    Warner Robins, GA
    what engine are you running?
    Southside Ridin HATCH
    For the TB, use a 68-70mm.
    The S2 Mani is good.
    I havent used a Performer X mani, so I cant vouch..
    And i assume this is for a gizzer?
    time for the build! jerseyef9's Avatar
    SOUTHSIDE
    skunk 2 if you not reving past 8.5k
    victor x if you reving 9k
    car should make great power otherwise
    R.I.P Booga
    M.A.P
    F.D.L.R
    Jan 2010
    We can do business
    Quote Originally Posted by r.etheridge View Post
    prbly ls/vtec or gsr havent decided yet I have the ls block and the whole gsr swap
    Jan 2010
    We can do business
    Quote Originally Posted by jerseyef9 View Post
    thanks
    i guess 70mm yea gsr or prbly lsvtec not sure yet i want power but dont want to be unreliable since I will be using stock rods wit rod bolts
    SOUTHERN SPEED
    macon ga
    We was running a stock f20b throttle body . it was around 65mm and car peaked at 7600 rpms . after putting 70mm on it made power all the way to 8100 . Your motor is alot smaller displacement then mine so a stock f20b throttle body would be fine . Since you got a 70mm i would use it since it want hurt you just no need to go any bigger. If your running pro series cams the 70mm will probably help since them cams are desighned to make hp higher in the rpms then the tunner series. I had 20 people tell me our motor wouldnt make over 240 with the stock throttle body but it made over 250 with it . If you dont get your head port and polished then the throttle body isnt going to help you cause the head want flow what the throttle body will.
    252plus hp and 34.5 miles to the gallon all motor. 12.2 at 111
    Southern Speed
    Macon
    Use the sk2 manifold over the performerx, and i had a 65mm tb on my 82mm 11.5cr setup. I would used something between a 65mm-68mm
    I'd say 68mm
    My line of work
    www.internationaljets.com
    Jan 2010
    We can do business
    thanks guys what if the head is ported?
    ^^^68-70mm. It will effectively increase velocity having a normal sized throttle body.
    My line of work
    Jan 2010
    We can do business
    cool cool... hmm some say 68 some say 70 hmmmmm...
    ^ yes man.. 68-70mm DO IT!
    It will support your future mods
    Jan 2010
    We can do business
    oh I will lol thanks bro!
    SOUTHERN SPEED
    macon ga
    i have a brand knew 68mm omni throttle body we can work something out if you want it.
    I can vouch for it!
    I believe its the one you picked up from my house, Along with that STEAL of a DEAL you got! lol
    Jan 2010
    We can do business
    Quote Originally Posted by h22 jones View Post
    lol.... man I would try but I'm trying to port the head and buy a mani so you can do both together... I HIGHLY DOUBT I have the money for it honestly.
    IA Member k_killaGSR's Avatar
    Oct 2010
    charlotte,NC
    id go with 68mm, in my opinion you dont need to go bigger than 68mm on a B series unless its a full stroked out, slaeeved, 13:1 plus compression race motor then id probly go with like a 70mm, im runnin a blox 68mm TB on my gsr making over 200...jhpusa has some blox 68mm TB for only 100..GET ONE
    Jan 2010
    We can do business
    Quote Originally Posted by k_killaGSR View Post
    jhpusa??? is that a website... and i tried ebay theyre $250 lmao
    dude go to ebay and type in this specifically: professional products 68mm throttle body
    You'll see they come up for $75 plus shipping and its not a fake since I've bought 2 of them and they are real and a higher quality than the blox. they don't stick and they look oem. When you get them its funny though because they shipped them in the factory box turned inside out.
    My line of work
    ^^ Hellz yea... Cool to know!
    Jan 2010
    We can do business
    dang I see them... thanks alot bro... I will be buying this real soon... do you know what other cheaper cam gear i can use with skunk2 pro cams??
    Blox is the cheapest name brand I see and they are 160 shipped. Look for some used ones but buy name brand ones.
    My line of work
    Im sure you can find some used Cam gears.. And yea I wouldnt rock the Ebay style or anything NOT brand Cam gears...
    I built a GSR for guy, and it had some off brand gears. The timing "marks" dont line up for shit! Its like a tooth off on each side.
    Oct 2010
    charlotte,NC
    Quote Originally Posted by Starrfire View Post
    You'll see they come up for $75 plus shipping and its not a fake since I've bought 2 of them and they are real and a higher quality than the blox. they don't stick and they look oem. .
    good find...just a fyi my blox doesnt stick either also looks like stock one, it doesnt come with the tps though. as for the cam gears dont cheap out on those for the reason black4drek stated
    Jan 2010
    We can do business
    dang. alright thanks guys thats all i needed to know
