Results 1 to 40 of 62
Thread: Random car stuff (i.e. injectors, gauges, ignition, etc.)
    Default Random car stuff (i.e. injectors, gauges, ignition, etc.)
    Price Drops!
    Most of the time I'm located in Warner Robins however on the weekends I'm usually in Atlanta so I can meet up in either area. 404 374 6710. My names Rick. Call or text, doesn't matter what time.
    Also these prices are not set in stone. Send me reasonable offers and I'll most likely go along with it. I used Google real quick just to try to get in the average price range so if you see something outrageously high let me know and I'll adjust accordingly. Thanks!
    $550- 91 Crx Si Transmission: Has a Quaife LSD, DX 5th gear (3500rpm 80MPH), Recently replaced 1st and 2nd gear synchro.
    SOLD- Stage 4 Competition Clutch 6 Puck sprung: Less than 10k on it
    $40- D series OEM Flywheel
    $400- T04E 57 Trim, Stage 3 Exhaust Wheel .63 AR, 3in V Band: Made 480whp with this turbo and has less than 3k on it
    $200- T04B M Trim, Stage 3 Exhaust Wheel .63 AR, 5 Bolt Flange: Made low-mid 300's, needs rebuild
    $120- Z6 Head
    SOLD! - Z6 Zex 59300
    $10- OEM Map sensor
    $20- A6 Throttle Body
    SOLD!- 4 Wire O2 Sensor
    $40- Z6 VTEC Solenoid
    SOLD! - D series Skunk2 Intake
    $10- 91 CRX Si Fuel Rail
    $10- 91 CRX Si Fuel Filter w/ Lines
    $10- 91 CRX Si Clutch Cable
    $10-Autometer angle rings: Opened it to check fitment and didn't like the way they look on my dash
    $10 each-Synchronic BOV adapter flange: One is greddy style and the other is weld on for synchronic
    $40-91 CRX Si gauge cluster: Works great just removed for a custom cluster
    $130- Lucas Style 550cc Injectors Peak & Hold
    $80- P08 Distributor Housing
    $20-Slim Radiator Fan 13"
    $20-Injector Resistor Box
    $30 each- Summit Racing Programmable RPM Switches
    $350 Single Cam ZC motor. Has approx 10k miles on it. It was rebuilt using all honda oem parts and had the rods shot peened. Runs fine. It was pulled out of the car for a swap.
    $60-P06 Distributor Housing.
    $20-D16Z6 Valve Springs
    $10-CRX Hood Latch Lever
    $20 each or Both for $30-A6 Intake Manifolds
    $10- Cable Speed Sensor
    $30-D16Y8 Camshaft
    $20-Charcoal Canister and Purge Valve with connector
    $10-Speedo Cable
    91 CRX SOHC-550WHP 420TQ (Sold)
    02 WRX-224.4WHP 223.2TQ (Traded)
    01 S2000 (stock)-201WHP 130TQ (Traded)
    98 GSR (stock block) - 415WHP 340TQ...Hydro locked. Sigh
    91 240SX POS - 0 WHP 0 TQ (Junked)
    10 370Z (Sold)
    97 Civic DX (turd awaiting polish)
    98 GSR (built) - 606WHP 366TQ @ 20 psi on 93 octane
    10 370Z (Sold)
    10 370Z (Sold)
    NITROUS JUNKIE
    home
    i want the 440 injectrs lmk
    PM'd
    10 370Z (Sold)
    10 370Z (Sold)
    pm'd
    10 370Z (Sold)
    Certified Gearhead Woody150's Avatar
    Lilburn, GA, U.S.
    Bump for a great guy AND good parts.
    1985 Toyota 4Runner "TRU 4WD"
    1995 Dodge Ram 3500 Cummins Turbo Diesel
    1989 Honda CRX Si
    1990 Suzuki GS500"R"
    Formerly:
    1995 Honda Accord H22 "US2JDM"
    1993 Honda Prelude VTEC "ECLUDE"
    much appreciated man
    10 370Z (Sold)
    10 370Z (Sold)
    more parts added
    10 370Z (Sold)
    Lilburn, GA, U.S.
    Is that the zc engine u told me about if my d16a6 finally goes?
    1989 Honda CRX Si
    Formerly:
    Certified Gearhead mr.egd15's Avatar
    Sep 2009
    Chicago, Illinois, United States
    hey man is any of them Distributor for a y8???????
    The P06 will work with the Y8
    10 370Z (Sold)
    Cat and wastegate sold
    10 370Z (Sold)
    NITROUS JUNKIE
    home
    whats the lowest for the 440 injector lmk whereu located
    I pm'd you twice I guess it didn't go through. Anyways call or text me @ 404 374 6710 for info
    10 370Z (Sold)
    10 370Z (Sold)
    <--- RIP :,( psycho_freke's Avatar
    Locust Grove
    *Bump for a good sale
    Last edited by psycho_freke; 10-23-2010 at 08:16 PM. Reason: Part probably won't work for me. Retracted offer.
    pm'd
    10 370Z (Sold)
    10 370Z (Sold)
    can't say that i do sorry, however if i come i across one i'll let you know
    10 370Z (Sold)
    Live in da fast lane
    Hey Bro interested in a Trade for the 440 rc injectors .. I got a 2000 si cluster with only 93k on it !! its like brand new !
    txt'd
    10 370Z (Sold)
    750's, 440's, and 2.5 Bar MAP sensor sold
    10 370Z (Sold)
    10 370Z (Sold)
    10 370Z (Sold)
    do you happen to have a d16a6 laying around
    yeah, the zc is pretty much the exact same motor. It's a direct replacement no funky parts needed. txt me at 404 374 6710 if you want more info
    10 370Z (Sold)
    i really just need the injectors off of a d16a6 because my 89 si hatch have a d16z6 swap and i don't know how to rewire my injectors so i won't have to use the fuel resistor box.
    dont have the injectors. however fyi the injectors i have for sale is meant for a resistor box.
    10 370Z (Sold)
    aem truboost sold
    10 370Z (Sold)
    10 370Z (Sold)
    10 370Z (Sold)
    10 370Z (Sold)
    10 370Z (Sold)
    10 370Z (Sold)
    10 370Z (Sold)
    10 370Z (Sold)
    my bumps are getting desperate. perhaps i should post the other parts laying around...
    10 370Z (Sold)
