Thread: 95 civic won't start
    Greene/Athens
    Default 95 civic won't start
    I've got a 95 civic ex (d16zc) that won't start. Head gasket was just replaced and now it won't fire. I'm getting all lights but the check engine light. Anybody got any suggestions on where to start? checked connections..
    Sep 2003
    Can you hear the fuel pump priming when you turn the ignition to the "On" position?
    eg6
    Apr 2009
    is it back in timing ...
    aye bro .:Stirfry:.'s Avatar
    first thing ill do is check the timing you probably have it 180 out.
    ATL DAsquad Member #9
    Greene/Athens
    Hey guys sorry it took a while to respond. I gave you some wrong info it's a z6 not zc idk what I was thinking. It turned out being a loose wire on the back of the head. (just got the car and having to backtrack other peoples work) Thanks for the responses. I'm officially boosted now, well after I replace the leaking feed line. Thanks for the help though
    the one on the T stat housing,. thats a main ground that everybody over looks.
