Results 1 to 3 of 3
Thread: HELP, LOCALLY BROKE PRESSURE PLATE BOLT!!
    IA Member bloodsport47's Avatar
    Default HELP, LOCALLY BROKE PRESSURE PLATE BOLT!!
    So im putting my clutch back in and I broke one of the 12pt. 10mm bolts that hold the pressure plate to the flywheel, if anyone locally has one that i can pick up tonite or tomorrow so i can finish by Monday I would appreciate it. Any help, thanks! Im in the Canton area and can go to bartow, gwinnett.
    Dahlonega
    go to lowes or home depot and get a grade 8.8 or up metric bolt. it is a m10x1.25 if i recall, 20mm long.
    take one to match up in case i am wrong. will be under $2.
    del sol? 94_teg_ls's Avatar
    im on the south side if you wanna drive
    /sig
