Results 1 to 3 of 3
Thread: FS: Dual Modded Street Fighter 4 Tournament Edition
    soon to be fast
    Default FS: Dual Modded Street Fighter 4 Tournament Edition
    $175 somewhat negotiable
    PS3->360.
    First priority is ps3, Dual modded with an Imp board (to be single USB wire) and 4716 360 controller PCB. Hex inverter hack done, so the triggers both work (all 8 buttons)
    If you want to use it on 360, all you have to do is put the switch onto RS before plugging it in.
    Otherwise, LS and DP cause it to be in ps3 mode.
    It's shell is a Round 1 Tournament Edition for SF4.
    It has an aluminum battop (heavy)
    Sanwa JLF joystick
    Sanwa Buttons
    Plexiglass cover
    Custom art I designed.
    the edges are jagged because i just wanted some art under it, so the ART ITSELF ISN'T CUT CORRECTLY.
    THE PLEXI IS PERFECTLY FINE, JUST SMUDGED.
    This is a picture of it as is, however, i can put it back to stock parts and color scheme.
    this is a picture of what it looks like if I'm to put it back to stock.
    buttons and joystick are still sanwa.
    testing waters on:
    round 2 TE (all black)
    NOT DUAL MODDED (Ps3)
    full panel plexi
    seimitsu buttons (clear, can insert art)
    sanwa JLF joystick
    red bubbletop
    custom Marvel vs. Capcom3 art
    DC5-R
    Gwinett
    looks good, this is way better than my setup, I've used happ buttons and a euro-il stick. Bump for quality parts but you're probably better off trying to sell these on shoryuken.com
    soon to be fast
    im just trying not to ship first.
    but i probably will if these don't sell locally.
    thanks!
