Results 1 to 15 of 15
Thread: H22 In a eg axle help
    revolution big mac's Avatar
    Default H22 In a eg axle help
    Just wanting to see what axles to run in a eg with h22 my passeger side axle keeps popping out
    AccuracyPerformanceAutomotive
    You may just need to loosen the clamp and slide the boot up closer to the inner hub. we just had a case like this, it had the correct axle, but it still popped out. We slid the boot in and no more problems. If you have the right axle.
    500whp of spinnin fury!!!
    The axle is out of a 96 gsr. How do you loosen the clamp
    Southside Ridin HATCH
    Its a straight H22?
    NITROUS JUNKIE
    home
    if its a str8 h..use the accord/prelude inner shaft..its longer an has a bit more play so the axles wont keep popping out..an the b series outters
    Yeah h22 with m2b4 tranny
    SOUTHSIDE
    ive heard DA axles work
    Driver side is good just clicks a little but passenger side keeps popping off so I might try da axles or make a custom just want to see what people on here thought
    If you get the accord half shft then you can use the DA axles for both sides. But a DA axle on the passenger side still may need the boot slid up.
    What's the differnce between half shafts? How do you tell em apart?
    SOUTHSIDE
    some have a female end and some have a male end.....no homo
    But make sure you dont get a AUTO half shaft... I had one and it didnt bolt up to the block correct.. and kinda made the axle seal leak..
    GL
    NITROUS JUNKIE
    home
    ok you have a couple of different choices. 90-93 accord 5 speed halfshaft with 90-93 DA integra driver side axel and DA integra pass. side axel with 90-93 accord inner boot (the part of the axel that goes inside the tranny, integra inner is too short and it will leak gear oil everywhere)..diff is the integra inners is shorter...the accord/prelude is a bit longer an have more play in side so the axle can move in an out..
    Okay gotcha. Driver side has no problems. But how can I tell what halfshaft I have with out taking it apart? It has the accord halfs it would be easier to do passenger side
    NITROUS JUNKIE
    home
    what driver side axle are u using? if its a da then u got the90-93 accord if u got the 96+ u got the 92-96 half shaft..
