What you see is what you get. no partin out.
to run this setup you have to grind off some of the block for the turbo to clear.
(or for the turbo to sit the right way, no backwards sittin stuff)
came off a running car, i got it and remade the dp setup for ac.
dnt need it bc im useing a different setup.
t3 A/R .60 ebay turbo very lil shaft play
38mm wg i believe its a 10 lb spring
greddy rep. bov
custom dp with dump tube (welded with flux core didnt have time to mig it. i was in a hurry)
comes with a flex pipe that has a flange to bolt to your exhaust and has 02 bung, hasnt been welded to the dp yet bc ppls exhaust setups very in length.
blox cast log style mani w/ the wg in the center.
comes with oil feed and drain flanges.
huge fmic 3inch in and outlets. fins are a lil beat up but it doesnt leak.
- its been capped off and tested.
misc cupplers clamps and some IC piping.
450 obo.
if you want it but dont have the money dnt waste my time. serious buyers only.
located in Warner Robins thats 1hr 14min frm summit and bout 2hrs frm the V.
call text
478 919 7497
sterling
pics of what i had to do to make it fit. only takes about 30 mins with a grinder.
