Results 1 to 4 of 4
Thread: cel # 4 on 1990 honda civc
    center field
    Default cel # 4 on 1990 honda civc
    its 1990 4 door civic auto , throwing cel #4 and wont rev pass 3,400rpm looks like a new dizzy was just put on . i reset ecu and still same problem any ideals .lmk thanks
    del sol? 94_teg_ls's Avatar
    its you dizzy i believe
    /sig
    Diagnostic Trouble Code (DTC) System Indicated
    0 Engine Control Module (ECM)
    1 Heated Oxygen Sensor (HO2S)
    3 Manifold Absolute Pressure (MAP Sensor)
    4 Crankshaft Position (CKP Sensor)
    6 Engine Coolant Temperature (ECT Sensor)
    7 Throttle Position (TP Sensor)
    8 Top Dead Center Position (TDC Sensor)
    9 No. 1 Cylinder Position (CYP Sensor)
    10 Intake Air Temperature (IAT Sensor)
    13 Barometric Pressure (BARO Sensor)
    14 Idle Air Control (IAC Valve)
    15 Ignition Output Signal
    16 Fuel Injector
    17 Vehicle Speed Sensor (VSS)
    20 Electrical Load Detector (ELD)
    21 Variable Valve Timing & Valve Lift Electronic Control Solenoid Valve (VTEC Solenoid Valve)
    22 Variable Valve Timing & Valve Lift Electronic Control Pressure Switch (VTEC Pressure Switch)
    23 Knock Sensor (KS)
    30 A/T FI Signal A
    31 A/T FI Signal B
    41 Heated Oxygen Sensor (HO2S) Heater
    43 Fuel Supply System
    /sig
    center field
    YEAH ITS DA DIZZY ANYBODY GOT 1
