Results 1 to 2 of 2
Thread: Honda/Acura FAQ (LSVTEC, Compression Calculator, ECU codes, etc)
    Default Honda/Acura FAQ (LSVTEC, Compression Calculator, ECU codes, etc)
    In an attempt to cut down on repeated questions, im doing a write up and gettign good info from other sites on FAQ about honda/Acuras. PM me if you want or see some info i missed.
    LS/VTEC Information
    Ls/vtec is the mating of the B18A/B to a B-series Vtec head like the B18C1, B18C5, B17A or B16A head. The amazing part about this swap is that the Ls blocks did not come with Vtec so there are a few mods you need to know to do the swap right.
    A. GENERAL INFORMATION
    1. The Down Side. The B18a/b has a low r/s ratio 1.53 which is not bad compared to the 1.58 of a gsr. The b18a/b was not made to rev over 7000 r.p.m's so it has poor lubrication, bad rod bolts, rods, oil and water pumps, and piston valve relief’s. You can fix all these problems, as you can install vtec block oil squirters for lubricating the rods and piston. This helps to save the pistons, rods and bearings at high rpm's. You can install ARP rod bolts. And get upgraded rods or shot-peined. Also some vtec pistons are recommended. An ls/b20 piston has a 31mm valve relief on the piston, a VTEC head uses a 33mm valve. so valve to piston contact is imminent if you use a big camshaft on a stock LS bottom end.
    2. Oil lines. The Ls block does not have a Vtec oil passage (you need this hole to produce the oil pressure to lock the vtec lobes rocker arm) so you will need to tap the hole on the head or weld it shut. When threading it shut use a 1/8ntp fitting. Its best to have a machine shop thread it for the 1/8th fitting and then just screw it in. Next you have to make an external line from the oil pressure sender to the head. Use a 4an to 3/8th ntp plug on the head to a steal braided line to tee'd of to the oil pressure sender hole. You will need a 1/8th tee fitting, a 1/8th to 3/4th's fitting for the line to the tee, a 1/8th to 1/8th adapter to plug the block, and plug the oil pressure sender in the back of the tee. So it will look like this (the T will be used as the tee fitting) 18th to 1/8th adapter T oil pressure sender sensor oil line to head. A suggestion is to have the tee fitting so it is not directly on the block (especially if you are installing an oil pressure gauge) as it can literally crack the threads and you will shoot oil everywhere. So try to run ss lines to someplace that can support the weight. Contact GOlden Eagle Manufacturing to buy their COMPLETE LSVTEC conversion kit for under $200(comes with headgasket as well)
    3. You will use the Ls head gasket.
    4. Dowel pins: The head needs to be modified for the dowel pins to fit. You have to move and re-drill the dowel pins to be able to fit the head. On the intake side right below where you put the 1/8pipe fitting that plugs the vtec oil passage, you will drill and install one of the dowel pins and do the same on the other side at the exact same point.
    5. Timing belt. You will use the Ls timing belt if you use the Ls water pump and the gsr if you use a vtec B17/16 or B18c1/5.
    6. Head studs. You will use the vtec head studs for the ls/vtec set-up. I suggest ARP if you want to spend the money.
    7. Oil Pump. The oil pumps on the ls's suck so you might want to upgrade to a vtec one or a b20 as they are same part number as the gsr.
    8. Heads. There are many heads you can use and there are little differences between them.
    First off there is the GSR head which give you a higher compression than the other b-series heads because of its 41.6cc combustion chamber. The smaller combustion chamber makes .2 more compression. Then there is the b16/17a head which are the same the only difference is that the b17a has a p61 stamped on the back of the intake manifold the b16/17a head is a better flowing head 5.25% in fact and a larger combustion chamber 42.7cc's. Then there is the type r which flows even better than the b16a head and has the same combustion chamber. To put this in perspective the b18a/b has a 45cc combustion chamber.
    9. GSR Block Girdle. You can use the GSR block girdle on the ls. This will reinforce the bottom end and keep the moving parts in its place. All you need to get is the 3 main caps in the middle, bolts, windage, oil pan and oil pick.
    10. Pistons. You can use any b-series vtec piston in your ls block. Any 1.6 b-series piston will be raised by about one full point in the ls block like the b16a(pr3 pistons will raise it from the stock 10.2 comp in the b16a to 11.2ish in the ls block so keep this in mind when building the ls block. Also keep in mind about the combustion chamber size (See heads) when building the motor. .
    11. Conclusion. This information should help you get an idea of what it takes to build an LS/VTEC motor. As always, please, if you don’t know what you are doing, call a mechanic who can help you with anything.
    B20VTEC is the same as LSVTEC except you use the B20 block instead of the LS block. what this does is get you Discplacement.
    A stock LS BLOCK with a VTEC head usually makes around 145-150WHP and 115TQ.
    A stock GSR usually makes around 145-150WHP and 110TQ.
    A stock B16 usually makes around 135whp and 100TQ
    All B series BORES are 81mm STOCK. The most you can safely bore a STOCK UNSLEEVED block is 82mm or 1mm over. 83mm for a race application.
    If you SLEEVE a b16 and bore it to 84mm you have a 1.8L now with a stock Crank.
    If you sleeve a GSR and bore it to 84mm you have a 2.0L now with a stock crank
    If you sleeve a LS and bore it to 84mm you have a 2.0l now with a stock crankshaft.
    THe safest you can bore a SLEEVED motor to is 85.5mm on the street. 86mm for race applications.
    Places that do sleeving:
    Golden Eagle
    Darton
    Benson
    RS MAchines
    AEBS
    expect to pay around $1000 for a SLEEVED block
    Compression Ratios:
    Here is a good site that does compression ratios for you, its not 100% accurate but gives you a good idea what combos do what for your D and B series.
    ECU Codes and Trouble shooting:
    ECU Thread and wiring for Swaps
    1 O2A - Oxygen sensor #1
    2 O2B - Oxygen sensor #2
    3 MAP - manifold absolute pressure sensor
    4 CKP - crank position sensor
    5 MAP - manifold absolute pressure sensor
    6 ECT - water temperature sensor
    7 TPS - throttle position sensor
    8 TDC - top dead centre sensor
    9 CYP - cylinder sensor
    10 IAT - intake air temperature sensor
    12 EGR - exhaust gas recirculation lift valve
    13 BARO - atmospheric pressure sensor
    14 IAC (EACV) - idle air control valve
    15 Ignition output signal
    16 Fuel injectors
    17 VSS - speed sensor
    19 Automatic transmission lockup control valve
    20 Electrical load detector
    21 VTEC spool solenoid valve
    22 VTEC pressure valve
    23 Knock sensor
    30 Automatic transmission A signal
    31 Automatic transmission B signal
    36 traction control found on JDM ecu's
    41 Primary oxygen sensor heater
    43 Fuel supply system
    45 Fuel system too rich or lean
    48 LAF - lean air fuel sensor
    54 CKF - crank fluctuation sensor
    58 TDC sensor #2
    61 Primary oxygen sensor
    63 Secondary oxygen sensor
    65 Secondary oxygen sensor heater
    71 random misfire cylinder 1
    72 random misfire cylinder 2
    73 random misfire cylinder 3
    74 random misfire cylinder 4
    80 Exhaust Gas Recirculation insufficient flow detected
    86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
    90 Evaporative Emission Control System leak detected in the fuel tank area
    91 Fuel Tank Pressure Sensor low input
    92 Evaporative Emission Control System insufficient purge flow
    Types of Honda MOtors available to Swap into your chassis:
    Possible Swaps
    Now before someone jumps on me and says anything is possible with enough time and money, I know. These are going to be fairly straightforward options with the pros/cons.
    D series swaps
    These are fairly inexpensive and come in a variety of Civics. IMHO, these are the easiest swaps to drop in. I also don't want to hear a bunch of whining about the opinions on power levels. Of course there are going to be some exceptions to the rule.
    Pros
    Inexpensive
    Decent potential (200 whp or so on stock internals)
    OEM parts are cheap
    More than enough for most people
    The best D series come with ~130 hp tops
    Optional factory LSD in the JDM D15B
    Cons
    Not as much potential as some other motors
    Transmission not geared for accelleration
    Don't respond to bolt ons well
    Only way to get real power out of them is FI
    B16
    These can be found in the JDM SIR and SIRII (among other JDM cars, which I don't claim to know all of which it came in) as well as the USDM 99-00 SI (EM1) and the 99-00 Canadian SIR.
    Pros
    160 hp stock
    High RPM power
    Fairly inexpensive
    Good transmission
    DOHC VTEC
    Cons
    113ft/lbs torque (very little more than a D16z6 stock)
    Without knowing what you're looking for you can end up with a high mileage JDM model
    Under 4k or so it feels just like a D16
    B18B
    This is the motor in the non Type-R and non GSR Integra.
    Pros
    Good torque for a 1.8L (127 ft/lbs)
    Inexpensive (even cheaper than a B16)
    142 hp (more than any stock D series)
    Boost heads love them
    Cons
    No VTEC
    Longest B series transmission
    B18C1 (or JDM B18C)
    These come out of an Integra GSR.
    Pros
    Good Hp and TQ numbers (170, 121 ft/lbs respectively)
    DOHC VTEC
    Tons of potential
    High revving
    Cons
    Expensive
    Becoming moreso as people keep scooping them up
    Slighty longer tranny than the ITR and B16
    B18C5 (or JDM B18C)
    This is found in the Integra Type-R. IMHO this is the best swap for a Civic.
    Pros
    GREAT HP and TQ numbers (195 and 134 ft/lbs)
    High revving
    Hand built motor from Honda
    Best transmission for a B series from the factory
    Red valve cover
    Cons
    EXPENSIVE
    If JDM ITR is used, the 36mm axle 32mm hub problems occur
    B16B
    This is the motor found in the Civic Type R found all over the world.
    Pros
    185 hp 117 ft/lbs
    High revving
    Good top end power
    Red valve cover
    Cons
    Expensive- almost as much as an ITR for lower performance
    Very little torque still, have to rev the motor to make power
    B20
    Pros
    Great torque (133 ft/lbs)
    good boost motors
    inexpensive
    B20z=146hp
    Cons
    Thin cylinder walls
    Have to peice together a swap for a Civic (can't drop it in with a B20 tranny)
    Won't pass BAR (light truck motor in a car)
    Low hp in the B20b(126 hp)
    H22/JDM F20B
    Pros
    200 hp
    H22=156 ft/lbs torque
    F20B=145 ft/lbs torque
    Great torque
    DONT WEIGH THAT MUCH MORE THAN A B SWAP!!
    http://honda-tech.com/zerothread?id=684550
    Cons
    Harder to install than a B/D motor
    transmission feel is vague IMHO
    Less info out there for the swap (aka, less experience as they are less common)
    Price of swap is comperable to a B18C5 after everything is said and done (mounts, etc)
    K20
    This can be found in the new EP3, the RSX (base and Type S) as well as other cars across the world (RSX R, etc). This is the future of the swap IMHO. There is a writeup on installing one of these in one issue of Sport Compact Car magazine (June 2004 I *think*)
    Pros
    200 hp 158 ft/lbs torque (RSX R)
    I-VTEC
    Respond VERY well to bolt ons
    6 speed transmission
    Most have very low miles
    Cons
    Still super expensive
    More difficult swap than a B or D
