Results 1 to 38 of 38
Thread: How do you cut Springs?
    Jan 2010
    Northside
    Default How do you cut Springs?
    What the easier way to go by doing so?
    your moms house
    ill be easier if you buy some no name brand from ebay until you get the cash to buy a good set cuttin the springs is bad sometimes trust me i done it before and sometimes one side is lower than the other one
    (((((No more 4 door))))))
    Jan 2010
    Northside
    Is there a difference in Ebay coilover or no name ones?
    Jul 2010
    c,ville
    dont do it because 99.9999999 percent of the time the car will drive like a bouncy ball.......
    Smyrna
    You can do it properly if you take you time. If you are content with cutting your springs, measure a few inches around the coil, marking it in increments. Be sure that when you mark the coil you want to cut, it is the "dead coils" in small increments. Start by cutting a small amount at a time, but beware that excessive heat can do damage to the spring itself. The biggest factor is determining how much you are trying to drop the car. If you are going less than a inch, then you could cut the spring. IMO and experience, anything greater than that, it is best to buy lowering springs. I have done it before to several cars. As long as you measure, cut properly, and take your time, it can be done.
    98 EJ8 - Stolen ( Thieves)
    Projects
    Yeah springs are cheap these days so its the best deal ive had cut when i was younger and it looks ok but rides like shit and ruins bushings ans suspension. If you wanna go really low then do coil overs and the only difference ive noticed between no name and name brand is no name strips or breaks sometimes.
    PEENGONE Hektik's Avatar
    How-do-you-cut-Springs
    Very carefully. Lol. Seriously tho. Just save the cash and get a set of eBay coilover sleeves. The Megan ones are alright. A bit bouncy but pretty decent IMO.
    Projects
    what you need them for ?
    *No_Pissed-ons!* chava_rx7's Avatar
    Braselton
    Quote Originally Posted by revenge View Post
    Not really, it depends how u go bout doing it, usually the more heat u apply the softer the spring gets thus u get the bounce effect, some people heat them up some cut with saw saw, I had lowering spring (eibach), and cut springs on my rx7 I wasent happy with the drop of the lowering spring so I sold them, and cut my stock springs, I took them off an cut them slowly, every time heat would build up I would dump it in water an then continue until cut, at the end you could only tell the difference between the brand name an cut springs under hard cornering because of the stock spring still being softer than the after market, cut spring are the cheapest way to lower ur car, if u got the equipment to do it, if not it will end up costing just as much if not more than a good set of springs, hope this helped
    Quote:
    Boy, your better off doing drugs because there isn't any rehab or therapy for rotaries or boost.
    Quote Originally Posted by chava_rx7 View Post
    Years of experience gives me the opportunity to disagree with this. I ONLY heat my springs so that I do NOT have a bouncy ride. More often than not, you'll get more of a bounce on cut springs. It's cheaper, easier and safer to heat than cut. I can't tell you to save up and buy springs if you want to "do it right" because I wouldn't do it. I'll take my propane torch over a set of dropped springs all day. Later, QD.
    San antonio 210
    Quote Originally Posted by KillZon3 View Post
    Dont cheap !
    GOON oneSLOWex's Avatar
    Chattanooga,TN
    What kind of car are you doing this on?
    use a hacksaw
    everywhere & nowhere
    Dropped springs > heated springs > cut springs
    end of that discussion.
    Coilovers ONLY are in the discussion bc they are adjustable, no tbc they ride so awesome. In a perfect world though, some proper lowered springs with the right shock will ride better than anything you can put on your car other than airride.
    Heated springs win over cut springs on any day, but still don't ride as well as some decent lowering springs and shocks.
    DO NOT cut your springs - hell even cheap springs will ride better and are much less work. Cut - install - ride around to let them settle - measure, then do it ALL again. To get it perfect you will have to repeat this process 5 - 10 times. Not worth it, ESPECIALLY since you can get NEW cheap(er) springs on eBay for cheap, and can even get NICE lowering springs used on CL / eBay for cheap as well.
    Certified Gearhead ftp's Avatar
    jawga
    cut em with a zizz wheel. opinions on this is like a asshole...everyone has one. All i can say is I have cut springs on my 4000lb pickup with a iron headed big block and its the shop truck so hauling motorcycles, engines, and pulling car trailers have been the norm for 5 years and i have not had a single problem. I aligned the truck in 20 minutes 5 years ago and its been great since
    Norcross
    ^ i can agree with this. 2 friends cut their springs and it rode n looked great.
    Earth
    My opinion on this matter is the right one.
    Northwest Georgia
    baby j you think heated is better than cut? lol
    Yes - bc heated springs do not drop out of the perch at the top if you ever catch a little air. They stay seated. I guess every1 has their opinion on it --- I just know what has worked for me in the past. Lowering springs are too cheap to be cutting OR heating... unless it's for an application that has zero aftermarket support.
    Northwest Georgia
    every heated spring ive seen looked like jumbled up melted metal on a stick lol
    ^ LOL - amateurs.
    Quote Originally Posted by SPOOLIN View Post
    That's exactly how they look. They aren't pretty, but a nice, smooth ride on ugly springs is better than a choppy ride on decent looking ones. Later, QD.
    Dec 2009
    lawrenceville
    I cut the springs on my integra n doesn't bounce at all n rides smooth
    RIGGER Sneezin's Avatar
    redtube
    we cut the springs on the sol and slammed it in the dirt....it rode just like any other lowered car to me...but just like ole buddy said this topic is like butt holes...everyone got one and to someone else it probably stinks!!!!
    Quote Originally Posted by b16panic View Post
    Yeah, but how low?
    Quote Originally Posted by Sneezin View Post
    Sure thing. Later, QD.
    Dec 2009
    lawrenceville
    [QUOTE=quickdodgeŽ;39109186]Yeah, but how low?
    Check out the signature really low....
    Dec 2009
    lawrenceville
    But yeah it depends on the way u cut them....b.c my friend cut the springs on his car and it lookd like a lowrider bouncing everysecond lol
    more wood than noahs arc sirkus's Avatar
    Cartersville, Ga
    I am riding around in a del sol with cut springs (got the car that way). It rides like ass. It's about 3" off the ground and it bounces so bad it will bottom out over bridges. It feels like it's about to punch you off the road when it hits the bottom. I had a buddy (in 2001) cut a 92 hatches springs too far and you couldn't drive it. Looked cool.. but it wouldn't make it over a speed bump. With as cheap as you can get a set from e-bay.. I don't see the point in cutting them anymore. More of a hassle really.
    My first mod on the del slow will be getting a set of real coilovers or springs and new shocks.
    2014 | Hyundai Veloster | Turbo R-Spec
    McDonough
    Just do it right the first time....get a good set of springs and shocks/struts to match....something like a Skunk2 combo.
    Bitches love bacon.
    Doesn't really make sense. If you know what you're doing, then there are several "do it right" options available. Later, QD.
    Senior Citizen Dylan's Avatar
    Milledgeville
    i have a friend who is riding a 4dr civic with cut springs, its low as shit and rides pretty damn well.and he had a civic before that with cut springs and it was the shittiest ride i've ever felt.and i've also had ebay coil sleeves.they are either going to ride super stiff or bounce you to mars.and as for my current car i recently purchased skunk2 lowering springs and they ride great and the stance is perfect.they are slightly bouncy at rr tracks but overall a great ride and they cost me less than $200.its your decision with what u ride on.you can play the cheap game and it be like a box of chocolates or you can spend a little cash and know what you're going to get.
    Going to be setting the Civic down about another 1 1/2" in the morning. Later, QD.
    Eurotrash
    Sep 2009
    in my own little world
    I need to heat mine in the rear a little more. This was my first time torching them, and I didn't want to go too far with them.
    lost 3'' in 3 hrs!!! 1moreaccord's Avatar
    l'ville
    ^^^ They may not look good, but they sure do the trick. Later, QD.
    May 2010
    South Side
    jus save up for adjustable coilovers its the best way bc it will ride better n easier to do
    Quote Originally Posted by uho View Post
    Lolol. Later, QD.
    l'ville
    Of that, there is no doubt. Doesn't get much cheaper than f-r-e-e!
