Thread: da eating up alternators... Help!
    Feb 2010
    Cedartown, GA
    Default da eating up alternators... Help!
    I did a b16 swap in my da in march and since then it has had three different alternators in it. i just put a reman in it about a month ago and it is slowly killing that one. i have gone through and checked all my grounds and made sure they are grounded properly. i am starting to get really frustrated with it. any suggestions are greatly appreciated.
    thanks everyone
    lovea92da
    Got vtak?
    Apr 2010
    check ur alr relay it could be sending more or less voltage than it needs, or a short somewhere, electrical problems are a pain in the butt for ppl that are not mechanics, like me, lol...
    but this happen to me and thats what my mechanic said it was wrong, so, i hope it helps
    i would replace the wires and check for excessive resistance on the wire and do some voltage drop test on the alternator control circuit.
    ^^this guy loves you jdm-civic's Avatar
    the sky
    get a oem one. i was having the same problem with the ones from advanced autoparts.i swapped on a used oem on the problem stopped.
    Emancipate yourself from mental slavery, non but ourselves can free our minds- Bob Marley
    facebook me: http://www.facebook.com/profile.php?id=779918877
    PEENGONE Hektik's Avatar
    Don’t know if this would cause it but check how tight the belt is. I would think that if it has too much tension it could put excess stress on the alternator.
    check your battery voltage because if it's low but enough to start, it'll make the alternator work to hard and wear out fast. If you have a load tester you can use that to check your alternator if the amps is working properly and if the amps output turns out to high that when you will know your alternator is working to hard.
