Results 1 to 40 of 75
Thread: TW/FS: 1998 Honda Accord, superjdmfreshtodeathomgisanaccordjdm?
    Default TW/FS: 1998 Honda Accord, superjdmfreshtodeathomgisanaccordjdm?
    Year: 1998
    Make: Honda
    Model: Accord
    Options: Power Windows, Power Door locks,AC,PS
    Engine: F23A1
    Mileage: 179,850 6-8k on motor
    Transmission: Manual
    Color: Flamenco Black Pearl
    Emissions is current
    Vin: 1hgcg5542xxxxxx PM ONLY
    Title: In hand
    Price: $10,000 obo (don't like the price, I don't care..I will keep whipping it or part it out one day)
    Mods:
    Engine: F23a1 (Vin matching motor)
    Golden Eagle 86mm (stock bore) sleeved
    CP 8.5:1 compression pistons
    Crower Billet rods
    ACL Race Bearings
    OEM oil pump
    OEM water Pump
    OEM rear main seal
    KaizenSpeed Balance Shaft Eliminator
    Oem Timing Belt
    Unorthodox racing Crank Pulley
    ARP H23 headstuds
    OEM headgasket
    Head Has been decked .020 to up compression to around 9:1 (factoryish)
    Head has port matched exhaust side, and has polished as well as intake manifold
    F22 Intake Manifold (To utilize a 2 wire IACV on intakemanifold)
    Stock cam,valvetrain
    OEM Cam seal
    Skunk2 adjustable cam gear
    New valve stem seals, intake manifold gasket
    New hoses/belts
    NGK plug wires
    NGK BKR7e-11 Plugs
    Wrinkle black valvecover
    New Wrinkle Red Valve Cover w/ custom Catch can
    Turbo Kit:
    Custom Turbo kit (by yours truly) Consisting of
    Huge FMIC, black, 2.5" hot side 3" cold side
    Custom Intercooler piping
    T bolt clamps and Silicon Couplers
    Log manifold
    Tial 38mm wastegate
    T3 Hifi 60 ball bearing w/ stg 6 wheels .48 exhaust housing turbo.
    3" Intake for turbo
    Stainless feed and drain lines New as of 7/20/10
    750cc injectors, flow matched,cleaned and checked to ensure proper flow as of 6/28/10
    Liquid Filled fuel pressure gauge fitted to factory rail
    B&M Adjustable FPR
    3" Turbo back exhaust w/ 3" straight exhaust
    OBD1 Injector clips
    Engine Managment:
    Crome Gold Chipped P28 w/ launch control, 2 step, and optional no lift shift wired in
    GM 3 bar Map sensor
    Boomslang OBD2b-OBD1 conversion Harness
    Tuned by the Great Scott Brooks
    Drivetrain:
    H22 Transmisson w/ Quaife LSD
    Fresh Fluid
    Extended Studs for front only (have ones for the rear just waiting for the rear disk stuff)
    Stock Axles (new) w/ warranty
    ACT XTREME Pressure plate w/ 6 puck sprung hub disk
    New clutch master cylinder
    Resurfaced OEM flywheel
    Stock shifter and cables
    Suspension:
    Tein Coilovers off of a 04 tsx
    Comptech Rear Sway bar
    Front Tenzo Upper Strut bar
    Brakes:
    New Brake Master Cylinder
    Fresh Brake hardware (slide pins)
    Brembo Blank disc's
    Hawk HP pads
    I will be doing the Prelude vtec 12" rotor w/ legend calipers and ss lines soon w/ new hawk pads (just have to stop being lazy)
    Exterior:
    Someone backed into the front bumper last June while I was at the gym so it may show on carfax etc
    The persons insurance covered it, and I managed to get all the parts, install them and get the car painted. It was a minor accident (i still have the old oem bumper just has paint flaked off)
    Replaced Front bumper w/ certafit
    OEM front bar that runs in between headlights as it was bent (somehow the trailer hitch didnt hit anything but that (thank god)
    Paint Fresh as of 7/09 OEM color
    30k Hids (blue in color) new as of 7/10
    Carbon fiber hood w/ key locks fresh clear coat at the same time as paint job
    Black housing headlights w/ yellow high beams
    ek9 sidemarkers
    Wheels:
    Volk TE37 Garcia Tune edition, chrome. 17 x 7.5 +42 offset
    Eagle GT front tires 215 45 17
    Cooper rear 215 45 17
    NeoChrome Lugnuts
    * new falken 225 45 17 for the front
    Interior:
    5% tint all the way around (the front strip is starting to peel a tad, probably going to get it redone soon)
    Custom mated NRG harness bar, you can still utilize the rear seats, and it is comfortable(so I've heard)
    Takata Harnesses w/ Memory Foam Pads
    EVO 8 Recaro seats on stock rails modified (fully slideable reclinable to an extent because of harness bar)
    Boss Steering wheel hub
    Omnipower quick release
    Personal (black and blue stitch) steering wheel
    Skunk 2 shift knob
    Flip out Dvd player
    Golf cart mirror
    Greddy turbo timer
    Factory "quartz" color interior (gray)
    Autometer Cobalt Oil PSI gauge (electric)
    Autometer Cobalt Boost gauge (electric)
    Autometer Cobalt Voltmeter
    Autometer Cobalt Narrowband (cool blinky lights bro)
    3 Gauge pod pillar 1 mounted in driver side vent
    Sparco CF pedals (with grippy shit)
    Engine Bay:
    Reflect-a-Gold heat reflective wrapped firewall (I was bored and thought it looked cool)
    Front and Rear Poly Urethane Engine mount Inserts
    AC freshly recharged, with new dryer blows ice cubes.
    Want to drive it? buy it, you will not test drive this car Unless you have cash in hand
    Car was my daily driver until I purchased another car, now I just drive it on the weekends the mileage will go up
    If you are nice, maybe I will throw in the pallet full of motors/transmissions and other shit I have accumulated over the many many years of owning this car, I have had it long enough to pay it off, Title in hand and I am the second owner.
    IF you have any question on this cars reliability, I have drivin it to florida,tennessee, deals gap, basically anywhere with 0 issues. IT has ONLY left me stranded when I destroyed a TRANNY at steele dragway.
    It Does not leak any oil
    It does drive me to wherever I want, whenever I want.
    The car in current form makes 347 whp 349 wtq, I have rarely drivin on high boost, as i really hardly need it.
    For all you non single cammers, put an h22 head on her and have a g23, rock out.
    The only bad:
    It puffs smoke inbetween shifting, only occasionally my only thought is that the valve guides have wear, and should be replaced. Not a big deal, and if It gets bad i'll just fix it, doesnt drink oil.
    basic shot of interior
    negros cant even bump? btw i notice that the turbo comparison isnt up so fail.
    lol thanks!
    Yea, I do drive her, but whats the point of building something you cant drive
    I am not sure why you mods feel the need to delete posts?
    be the envy of all your friends
    I'm about to do the same with my Prelude. If by some act of God money comes my way, i'll give you a call.
    Just out of curiosity.... trade for my lude? You pretty much know what it is.
    No thanks on the trade, It would almost be like starting over lol
    South Side Georgia
    I might have missed it but what kinda power this thing making?
    resize pic
    power is in there. and dont do it?
    sure, 10k, come with a free car.
    sleeve me please?
    monroe
    interested in trades at all? plus cash
    What you got?
    ttttttttttttttt
    ttt
    Kennesaw, GA
    Damn I love this car! I'd hate to see it go man
    NIKON Squad member 01
    OF*C
    OEMFitment Crew Memeber 01
    ttttt
    tttt
    Certified Gearhead jmotley's Avatar
    Jul 2009
    LaFayette
    would you take 10 million dollars?! bump.....glws.
    yes i would, come get it
    Spraypainter Gabe's Avatar
    United States of Atlanta
    if u decide to part anything out holler at your boy cause u already know what i want!!!
    Gabe
    revolution big mac's Avatar
    Clean car man h22eg?
    pix?
    Txt me and I'll send u some. I can't post em here from my phone. 6788636927. Btw what is best time at track?
    lol best time at the track was 14.1 @ 106 mph, with 280hp.
    Did u txt me? What do you think it will do now?
    It should have been faster back then, just always ran on street tires. I don't know what it will run because i havent taken it back. No haven't texted you.
    Is that long live h2b's old car?
    I don't know man it might be. I pit alot if my own parts on since I got it and fixed alot of problems.
    ttt
    lost 3'' in 3 hrs!!! 1moreaccord's Avatar
    l'ville
    bump for a look and epic name that had me loling.. very cleannnn!
    yyy
    Found out this was his old car bro
    cool, thanks anyway, too much nitrous for me ..lol
    buy me
    Lol I'm surprised it runs so well as much as it got sprayed. It hasent had spray in a while but that bout to change
    ........... PrOjEk_EJ's Avatar
    NICE !!!! G/L
    ttt
    going
