Results 1 to 19 of 19
Thread: How to: Roll fender
    Post How to: Roll fender
    My rear tire sidewalls were rubbing against the rear quarter panel's lip:
    Quarter panel's lip before rolling:
    (the tire actually caught on the lip, and yanked it downwards slightly)
    Have the car up on jack stands, and remove the wheel.
    Mounting the fender roller tool:
    Adding the lug nut washers:
    Lug nuts on, and slightly tightened:
    What the tool looks like fully mounted:
    Since I'm working on the rear, the e-brakes will need to be released.
    Tool is positioned with slight pressure on the panel lips.
    Red knob tightened to lock the tool length in place.
    Head roller angle is also tightened and locked into place:
    With slight pressure already on the panel lip, rotate the tool left and right several times. Lip starts to slightly curl:
    Use the lever to add more pressure on to the panel lip, and rotate the tool left and right several times again. Repeat this step until the panel lip is folded enough to clear the tire:
    Some paint cracking depending how much the lip is folded:
    (Paint cracking maybe reduced if a heat gun was used prior to rolling)
    Fender rolling completed:
    (The dimple shown is a factory spot weld, but is not visible on the outside)
    Finished:
    *** For more photos of this car: http://www.rimtuck.com/setup.php?id=1066
    Oct 2009
    G-Net G.A.
    NICE did you rent the rolling tool or you bought it.
    No Advertising unless you pay you are Warned...
    IA MGMT
    Newburg, MD
    looks good
    RIP Kaleb Mashburn
    love it, nice job and nice Z
    Great how to and very nice Z!
    Senior Member EJdm's Avatar
    great job...love the Z...
    "Arriving at one goal is the starting point to another." – John Dewey
    loa13 loa706's Avatar
    Jan 2010
    ICE CITY/CHATT/DALTON
    need a fenderroller asap or some1 to roll mines......706 280 2323
    BLUEBERRY
    I fender roll give me a call @ 404 seven75 3143
    Certified Gearhead Hatmanafro's Avatar
    Jul 2010
    Bethelehem, GA
    i hammered my lip. lol.
    89 Sexima___VG30E
    Cragar Steel D-Window Wheels____15x7, 0 offset
    Aug 2010
    atlanta
    i need to rent a fender roller or pay someone to roll my fender's
    signatures are whack :idb:
    ZOMG ChnkyLao's Avatar
    Winder, GA
    i did mine with a baseball bat, which i dont recommend if ur not a patient careful person
    nice
    IA MEMBER YokotaS13's Avatar
    saudi arabia
    so simple to make a video guys
    here ya go. did this a while back
    Columbus GA
    Fender rolling is too easy to even be discussed. Someone post up their quality pulled/flared jobs, thats what i want to see.
    saudi arabia
    look at any of my cars then...
    Columbus GA
    Quote Originally Posted by YokotaS13 View Post
    can you do this?
    Salty Devil Dog eklanta's Avatar
    Beaufort, South Carolina, United States
    Good how to. i used a metal pipe and a blow dryer. then slightly moved to a bigger pipe to flare it out. not much but some.
    1371 Combat Engineer
    United States Marine Corps.
    saudi arabia
    can you do this?
    yes. do i want to?
    no
    i hate that look.
    Krispy Kreme
    that is a cut fender, with a custom flare, and repainted, ive seen it on gs300's.
    NIKOND80
    PG+K
Tags for this Thread
