Thread: cel help
    IA Member googoo's Avatar
    Dec 2008
    tyrone
    Default cel help
    ok just got a p28 with a ctr map on it and 2-step control that im running on my b16a2. and once i put it in the car my idle is at 2000 rpms and is kinda rough. my check engine light is on and tried to retrieve the code but when i jump the harness the cel stays on and the srs light flashes.... i dont know what the fuck is going on can someone that is smarter than me please help... also while i drive i cant go past 4800 rpms cause the 2-step kicks in im assuming thats not supposed to happen ....thanks
    aye bro .:Stirfry:.'s Avatar
    did it do that before you put that ecu in?
    ATL DAsquad Member #9
    possible bad ecu
    Dec 2008
    tyrone
    Quote Originally Posted by .:Stirfry:. View Post
    no i had a untuned chiped p28 in it before
    well did it do the same thing before. bc it might just be a bad ecu
    Certified Gearhead RHD_Joe's Avatar
    It's either a bad map or a bad ECU..
    PG+K
