Results 1 to 17 of 17
Thread: d series turbo
    nvr too low jco224's Avatar
    Jul 2009
    Carrollton georgia
    Default d series turbo
    i just installed a turbo kit on my 96 civic lx. it has a 10lb wastegate but is only pushing 6 lbs due to the stock injectors. What size injectors do i need to install to get my 10 lbs? and if anybody has ssome let me know please
    aye bro .:Stirfry:.'s Avatar
    so your fuel system is stock? is it tuned? put some dsm 440cc and call it a day
    ATL DAsquad Member #9
    Jul 2009
    Carrollton georgia
    yea the fuel system is stock except for fuel pressure regulator and im waiting to get a tune until i get bigger injectors. but isnt 440cc a lil too big?
    1990 mazda rx7 TII
    Oct 2008
    brookhaven
    General rule of thumb. Its better and easier to remove fuel than it is to add in fuel. you should always go with bigger injectors when putting a turbo into an engine. PERIOD. also, getting a bigger fuel pump is needed as well.
    Jul 2009
    Carrollton georgia
    yea i knew all along i needed new injectors but i dont know what size to use..
    del sol? 94_teg_ls's Avatar
    i got 560cc dsm evo ones that will do the job
    /sig
    Feb 2010
    Zebulon
    what power are you looking to make?
    560 will cover to about 270.
    replace the fuel pump also.
    Fuel injector size calculator HERE
    Jul 2009
    Carrollton georgia
    someone told me to go with 315cc with 10lbs boost and will make 220-240 hp....suggestions? i can get the 315's for cheap but i dont wanna buy them if theyre not gunna do anything?
    i have no clue about what injectors can do what i always just buy 550ish injectors to leave room to grow try that link xero posted up
    /sig
    Norcross
    i got RC 440cc inj for sale..
    AccuracyPerformanceAutomotive
    Injectors wont make psi. If the wastegate has a 10psi spring in it and you are only making 6psi, then you have a 4psi pressure drop. BUT you do need injectors and a good tune to run that save.
    I have 780cc injectors in my car and im about to install a set of 1000's. D16y8 t3/t4 turbo.
    500whp of spinnin fury!!!
    Jul 2009
    Carrollton georgia
    750cc for a dd?
    Feb 2010
    Zebulon
    i can put 1000cc injectors on my d15b7 and run it all day long. it will have amazing throttle responce, but it will change verry little.reasonably 550cc inje tors are fine. 750 for upgrades later or running more psi. use the calculator i posted earlier. and it will tell you what you need. it will give it to you in terms of power goals, but if your only looking for 220 or so, then 550 will be fine.
    I have my car street tuned on 780's tuned to 29-30mpg, making 3xx whp. But 550's would do fine.
    Jul 2009
    Carrollton georgia
    well it looks like im goin to 550..im not looking for anything crazy fust 220 at 10lbs...i just hear to get nothing more than 315cc.. but thanks for the help
    92 Hatch redneckhatch's Avatar
    White Castle
    barrow county
    i have a fmu, it'll push your lower cc injectors a little farther and no need for fuel pump upgrade
    10 bucks pick up
