Thread: KIA ::: KNocking and shutting off
    Certified Gearhead never2loud's Avatar
    Default KIA ::: KNocking and shutting off
    HEy,
    i got a problem with a kia van im working on, its a 2003 KIA sedona 3.5L, i replaced spark plugs, coil, and wires, and now it is making a knocing and then shuts off. before i did this the motor ran fine just needed a tune up and motor mounts, ran good before just sluggish. im pretty sure its just needs a carbon cleaning, ive ran into this before and the shop did a carbon clean and then it ran fine. So i need to know if anyone knows what they do or use to do this. So i can do this at home.
    or if anyone knowxs what else it could be would be great!!!
    LAWRENCEVILLE
    wires crossed?
    Hella stock member!
    i will try, switching but i think it will still keep knocking
    im a organ donor :) 00 blk G20t's Avatar
    Nov 2009
    canton GA
    man, seems like alot of threads lately on tune ups gone wrong. good luck finding the problem. hopefully its something simple.
    Best G20 SR2009 convention
    in attendance Nissan national convention 2010(Omaha, Nebraska)
    top 20 hotlanta autofest 09
    Projects
    Quote Originally Posted by never2loud View Post
    it sounds just like cross wired like silversol said. Only other thing i could think to make it knock then shut off is oil pump going out or bad
    thanks it started and ran but still knocking so i think i know what to do but not 100% i think i got carbon build up in the cylinder so i gotta blow it out with an air compressor through spark plug holes, wish me luk
    del sol? 94_teg_ls's Avatar
    dont do it seafoam it
    /sig
    Banned STRteg's Avatar
    Oct 2008
    Somewhere in the USA
    Quote Originally Posted by 00 blk G20t View Post
    man, I've seen alot of threads lately on noobs not knowing what they are doing gone wrong. good luck finding the problem. hopefully its something simple.
    Fixed
    Default screwed motor in kia
    well the knocking and skipping in the kia had metal shavings all in the cylinder so its screwed up. the walls are probably scarred and head too.
    anyone know where i can get a good cheap kia motor, its the 3.5l and it seems like this motor was used in alot of models even hyundai so i know to check junk yard but other than thati dont know. its probably cheaper to buy a new van.
    suks big time its my grandmother van she ran it without oil, for however long and now im screwed b/c i said id fix it.
    Oct 2003
    Oh, you fixed it alright
    yeah i know well it was it is i wish it was as easy as my integra
    Oct 2003
    Take the motor out from the bottom. Use a couple of jack stands and jack the front of the van as high as possible. Lower the motor still attached to the subframe with a pair of floor jacks.
