Results 1 to 4 of 4
Thread: ls tranny problems
    Default ls tranny problems
    i have a 95 integra with a gsr motor and ls tranny for a while my reverse gear mad noise when in gear but fixed that issue and changed the hole clutch set up when i fixed the reverse problem today i finally got to test everything and driving the all gear hitting v tec its fine but when i slow down have problems down shifting wont just slide into a lower gear like it usto and at a dead stop from driving sometimes wont go into 1,2,3,4 or 5th unless i turn the car off and put in gear woundering if anyone heard of it would not be asking but took the tranny out twice in a week already lol hope someone can help thanx
    del sol? 94_teg_ls's Avatar
    slave or master or air
    /sig
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    How does the clutch pedal feel? Was the throw out bearing installed correctly? That will happen if the clip is not all the way n place against the fork...
    98 Acura Integra LS-DD
    ??????????????????-project
    the fork was put on right the master and slave are new i guess i can bleed it again
Tags for this Thread
