Thread: 97 Civic LX [5spd] - engine loses power and 'chokes' ?
    Default 97 Civic LX [5spd] - engine loses power and 'chokes' ?
    Hi,
    I have a 97 Honda Civic LX 5 speed.
    When i accelerate slowly, about 45% of the time, the car will start losing power (RPM's drop) and than feel like it chokes and than goes on..
    Lately it feels like it loses power more often and longer than before, however if i accelerate (floor it) it doesnt do it at all.
    I was recommended to change fuel filter, which I did.. and it still has the same problems.
    Feb 2010
    Zebulon
    when the car is in neutral, do the rpms surge?
    when you try to rev the car, does it redline or does it limit its sellf befor that point?
    what is the mileage on the car?
    when was the last time you service the throttle body?
    replaced the air filter?
    had any recent ENGINE SPECIFIC service done to it?
    No
    It revs fine even to redline
    ~155000
    Not sure, had a tune up awhile ago, do not know what that consisted of tho
    Same time as the tuneup about 2 months ago
    None
    Greene/Athens
    Is your check engine light on? If so, What codes are you getting?
    Certified Gearhead RHD_Joe's Avatar
    sounds like a potential TPS or MAP sensor problem
    PG+K
    Quote Originally Posted by joshk5145 View Post
    no lights on.. therefore no codes...
    hard to change?
    i have asked a few mechanics.. but they cant figure it out.. so one suggested to drop to his house for a few days..
    no one else had this problem ?
    Feb 2010
    Zebulon
    it is not a TPS proplem. it revs fine and no codes. new fuel filter.
    it is an injector problem. service them, test them or replace them. if you pull the injectors and they are mucky/gunked up with black then there is your problem...
    noticed poor fuel economy?
    Aug 2010
    canton,ga
    i have a 98 civic lx 5spd and i had the same problem and i did everything u did but in the end it was my dizzy so u can try that too.
