Thread: obd0 to obd1 in a 90ef
    BattleArena FTL!!
    Default obd0 to obd1 in a 90ef
    I recently purchased a 1990 civic hatch std, with a gsr swap. The car has been converted to mpfi, and is currently running on obd0. Obviously the car is not running to its full potential on obd0, and i would like to convert it to obd1. My first question is how hard is the conversion, and secondly what parts will i need to do it?
    Thanks for the help.
    00 prelude (dead)
    92 240
    07 Fj
    94 Civic
    11 Camry
    Conversion harness, distributor, ecu, few other small things. it's easy.
    BattleArena FTL!!
    00 prelude (dead)
    92 240
    07 Fj
    94 Civic
    11 Camry
    in a paint booth
    it is actually really easy rywire.com makes everything for the conversion the harness for the ecu and the harness to go from the obdo plugs on the old dizzy to the obd1 plugs of the new dizzy so the only thing you have to wire up is the 4 wire o2 sensor and and the jumper wire for the check engine light to check codes
    BattleArena FTL!!
    Thanks a lot.
    00 prelude (dead)
    92 240
    07 Fj
    94 Civic
    11 Camry
    Conversion harness
    VTEC OBD1 distributor
    Repin the distributor to OBD1
    OBD1 ECU
    its pretty simple.
    BattleArena FTL!!
    Hey vteckidd i tried to pm you about some parts but you mail box is full.
    00 prelude (dead)
    92 240
    07 Fj
    94 Civic
    11 Camry
    its clear now
    BattleArena FTL!!
    pm'd
    00 prelude (dead)
    92 240
    07 Fj
    94 Civic
    11 Camry
