Thread: Sportsman Import Compact Championship (SICC) September 11, 2010
    Northwest Georgia
    Default Sportsman Import Compact Championship (SICC) September 11, 2010
    Who's going? I know we can't wait to go to this, since it got rained out and rescheduled that allowed me to be able to go! It will be in the evening which means no death heat to ruin the power.
    This will be a "NIGHT RACE"
    September 11, 2010
    Gates open @ 3pm
    Qualifying Starts @ 6pm
    General Admission $20.00 - $5.00 off with flyer
    Heads up Racer $75.00
    Bracket Racer $40.00
    Car Show $25.00
    FMSP
    Fayetteville Motor Sports Park
    4480 DOC Bennet Road
    Fayetteville, NC, 28305
    www.fayettevillemotorsportspark.com
    RULES:
    Street "ALL MOTOR" Bandit
    Designed for naturally aspirated FWD/RWD Import/Compact vehicles, Heads up, Quick 16 field, Pro ladder, .400 Pro tree, No break out, 1/4 mile Drag Racing
    All vehicels and drivers must comply with NHRA/SICC safety rules and regulations.
    Minimum weights Requirements
    4cyl FWD Honda/Acura F/K series (2.0l-2.2L) 2150lbs
    4cyl FWD Honda/Acura F/K series (2.3l-2.6L) 2200lbs
    4cyl FWD (any other) (2.6L) 1900lbs
    4cyl RWD (any other) (2.7L) 2300lbs
    2 rotor ( Rotary) 2300Lbs
    6cyl FWD all manufactures (all out) 2300lbs
    ENGINE:
    Engine swaps are permitted but must be from the same manufacturer as the vehicle. OEM After market mount kits (ex.D2B, H2B, F2K,) are permitted but must be available for over counter purchase. Dry sump oil system prohibited!
    BODY:
    Import or Domestic compact vehicles. Light weight body components are permitted but limited to: Hood, front fenders, hatches, trunks lids, sunroof plugs, wings, ground effects, bumpers, and doors ( must be factory operational ).
    Chassis:
    OEM chassis with complete OEM floor plan and firewall mandatory. Wheel tubes back half conversions, tube chassis, etc prohibited, engine must be in OEM location.
    Suspension:
    Aftermarket front and rear control arms and suspension are permitted but must utilize factory mounting points. IRS conversion to straight axle, ladder bars, four links, wheelie bars and spindle mounted wheels are prohibited.
    Street Equipment: Headlights and tail lights can be replaced with aftermarket units but must functional. One headlight can be removed for induction.
    Windows: All windows must be OEM style, non functional. NON OEM (Lexan) Points!
    Interior: Complete Interior, including dashboard, headliner, door panels, carpet and front upholstered seats. Points!
    Exhaust: Open exhaust permitted, unless track rules differ.
    Transmission: Automatic transmission must be from same manufacturer as engine used in vehicle. Manual transmissions must be clutch assisted, from the same manufacturer. Aftermarket internals permitted but must utilize OEM case. Aftermarket bell housings, axels, gears, spools, and differentials are permitted. Sequential transmissions prohibited!
    Electronics: Delay boxes, prohibited
    Tires: FWD 24.5x9 max RWD 26x9 max
    Clutch/Shifter:
    Clutch must be manually operated, shifter must be H pattern, air/electronic shifters prohibited!
    Driveline:
    Open to FWD/RWD vehicles.
    Fuel:
    Gasoline and E-85 permitted, Alcohol prohibited.
    Fuel Injection:
    Aftermarket fuel injection, individual throttle bodies permitted.
    Power Adder: Prohibited
    Payout: $2,500
    REAL STREET
    Designed for FWD/AWD/RWD Import/Compact vehicles powered by 1 power adder. Heads up, Quick 16 field, Pro ladder, .400 Pro tree, No break out, 1/4 mile Drag Racing
    Engine Driveline Power Adder Min. Weight
    4cyl FWD 67mm max 2400 lbs
    4cyl AWD 67mm max 2800 lbs
    4cyl RWD 67mm max 2700 lbs
    2 rotor RWD 72mm max 2600 lbs
    6cyl FWD 67mm max 2600 lbs
    6cyl AWD 67mm max 2800 lbs
    6cyl RWD 72mm max 3500 lbs
    Twin Turbos: allowed T3 50mm add 100Lbs
    Nitrous: combined with Turbo (automatics only) 100 lbs
    Nitrous only cars: Deduct 200lbs
    FWD: Turbo .63 or smaller Deduct 150lbs
    FWD: Single Cams Deduct 150lbs
    ENGINE:
    Engine swaps are permitted but must be from the same manufacturer as the vehicle. OEM After market mount kits (ex.H2B, F2K,) are permitted but must be available for over counter purchase. Dry sump oil system prohibited!
    BODY:
    Import or Domestic compact vehicles. Light weight body components are permitted but limited to: Hood, front fenders, hatches, trunks lids, sunroof plugs, wings, ground effects, bumpers, and doors ( must be factory operational ). Wide fenders (EX. Callos Front End) permitted.
    Chassis:
    OEM chassis with complete OEM floor plan and firewall mandatory. Wheel tubes back half conversions, tube chassis, etc prohibited. Engine must be in OEM location, excessive lightening of chassis by cutting, drilling, prohibited.
    Suspension:
    Street Equipment:
    Windows:
    All windows must be OEM glass and must fucntion like OEM.
    Interior:
    Complete Interior, including dashboard, headliner, door panels, carpet and two front upholstered seats. Points!
    Exhaust:
    Full exhaust or exhaust must pass underneath car with muffler attached. Points!
    Transmission:
    Tires: FWD 24.5x9 or 25x8.7 Max
    RWD 28x11.50, 275 DRAG RADIAL ET Streets
    AWD 225, 235, 245 series Drag Radial Max
    Clutch/Shifter:
    Clutch must be manually operated, shifter must be H pattern, G-forse/T1 style shifter air/eclectronic shifters prohibited!
    Driveline:
    Open to FWD/AWD/RWD vehicles.
    Fuel:
    Gasoline , E85 permitted, fuel cells must mount in rear of car, alcohol prohibited.
    Payout: $1,500
    EXTREME 72
    Designed for FWD/AWD/RWD Import/Compact vehicles powered by 1 power adders. Heads up, Quick 16 field, Pro ladder, .400 Pro tree, No break out,
    4cyl FWD T4 72mm 2500 lbs
    4cyl RWD T4 72mm 2650 lbs
    4cyl AWD T4 72mm 2750 lbs
    2 rotor RWD T4 74mm 2500 lbs
    6cyl FWD T4 72mm 2600 lbs
    6cyl AWD T4 72mm 2800 lbs
    6cyl RWD T4 74 mm 3100 lbs
    Twin Turbos: allowed T3 54mm MAX add 100 lbs
    Nitrous: add 100 lbs - 67mm turbo Deduct 100lbs
    Nirtous only: Deduct 200lbs
    RWD: Aftermarket Trans 100 lbs (TH400, Powerglde, non oem manual)
    ENGINE:
    Engine swaps are permitted, OEM After market mount kits (ex.H2B, F2K,) are permitted but must be available for over counter purchase. Dry sump oil system prohibited, N/A cars run what you bring.
    BODY:
    Chassis:
    Suspension:
    Street Equipment:
    Windows: All windows must be OEM glass and must fucntion like OEM. Mandatory!
    Interior:
    Exhaust:
    Open exhaust permitted, dump tubes may protude hood. Points!
    Transmission:
    Automatic transmission must be from same manufacturer as engine used in vehicle, aftermarket transmission subject to a 100lbs weight penalty. Manual transmissions must be clutch assisted, from the same manufacturer. Aftermarket bell housings, axels, gears, spools, and differentials are permitted. Sequential transmissions prohibited!
    Intercooler: AIR to AIR only, liquid to air prohibited
    Tires: FWD 25x9.5 or max
    RWD 28x10
    AWD 24.5x8 max
    Clutch/Shifter:
    Clutch must be manually operated, air/eclectronic shifters prohibited!
    Payout: $2,500
    SIC OUTLAW
    4cyl FWD Natural Aspiration all out
    4cyl FWD T4 74mm 2400 lbs
    4cyl RWD T4 74mm 2500 lbs
    4cyl AWD T4 74mm 2700 lbs
    2 rotor RWD T4 76mm 2500 lbs
    2 rotor RWD Natural Aspiration all out
    3 rootr RWD Natural Aspiration all out
    6cyl FWD T4 74mm 2600 lbs
    6cyl AWD T4 74mm 2800 lbs
    6cyl RWD T4 76 mm 3000 lbs
    Nitrous: add 200 lbs
    RWD: Aftermarket Trans add 100 lbs (TH400, Powerglde, non oem manual)
    ENGINE:Engine swaps are permitted, OEM After market mount kits (ex.H2B, F2K,) are permitted but must be available for over counter purchase. Dry sump oil system prohibited, N/A cars run what you bring.
    BODY:
    Import or Domestic compact vehicles. Light weight body components are permitted but limited to: Hood, front fenders, hatches, trunks lids, sunroof plugs, wings, ground effects, bumpers, and doors ( must be factory operational ). Naturally aspirated vehicles are allowed to run what you bring!
    Chassis:
    OEM chassis with complete OEM floor plan and firewall mandatory. Wheel tubes back half conversions, tube chassis, etc prohibited. Engine must be in OEM location, excessive lightening of chassis by cutting, drilling, prohibited. Naturally aspirated FWD allowed full tube, RWD N/A allowed 3/4 chassis!
    Suspension:
    Aftermarket front and rear control arms and suspension are permitted but must utilize factory mounting points. IRS conversion to straight axle, ladder bars, four links, wheelie bars are prohibited except N/A cars.
    Windows:
    All windows must be OEM glass and must fucntion like OEM. NON (OEM) Lexan Points!
    Interior:
    Including dashboard, door panels, carpet and 1 upholstered seat.
    Exhaust:
    Transmission:Automatic transmission must be from same manufacturer as engine used in vehicle, aftermarket transmission subject to a 100lbs weight penalty. Manual transmissions must be clutch assisted, from the same manufacturer. Aftermarket internals permitted but non OEM case will be subject to 50lb weight penalty. Aftermarket bell housings, axels, gears, spools, and differentials are permitted. Sequential transmissions prohibited! .
    Intercooler Air to Air, Air to Water permitted
    Tires: FWD 26x10 max
    RWD 28x10 max
    AWD 26x8.5 max
    Clutch/Shifter:
    Clutch must be manually operated, air/electronic shifters prohibited!
    Payout: $3,000
    TOP MODIFIED
    Designed for FWD/AWD/RWD Import/Compact vehicles powered by 2 power adders and alcohol. Heads up, Quick 16 field, Pro ladder, .400 Pro tree, No break out, 1/4 mile Drag Racing
    4cyl FWD 80mm 1900 lbs
    4cyl RWD 80mm 2400 lbs
    4cyl AWD 80mm 2500 lbs
    2 rotor RWD 80mm 2400 lbs
    6cyl FWD 80mm 2100 lbs
    6cyl AWD 80mm 2700 lbs
    6cyl RWD 88 mm 3000 lbs
    Twin Turbos: allowed T4 60mm MAX add 100 lbs
    Nitrous: combined with Turbo add 100 lbs
    RWD: Back Half 4 cylinder only add 150 lbs
    6cyl: 91mm max add 100 lbs
    Single Cams: Deduct 100 lbs
    ENGINE:
    Engine swaps are permitted, swaps of different manufacturer allowed, must meet weight requirements. Dry sump oil system permitted
    BODY:
    Import or Domestic compact vehicles. Light weight body components are permitted but limited to: Hood, front fenders, hatches, trunks lids, sunroof plugs, wings, ground effects, bumpers, and doors must open and close from inside and outside vehicle. FWD allowed one piece front end.
    Chassis: RWD back chassis, mini tubs are permitted. AWD/FWD cars must retain stock firewall and front strut towers only, back half AWD/FWD chassis Permitted.
    Suspension:RWD vehicles must utilize stock front suspension mounts, mini tubs, ladder bars will be permitted. AWD vehicles must utilize the front stock suspension, but may utilize any type rear suspension. FWD must utilize front shock towers and may utilize any rear suspension, wheelie bars permitted, aftermarket front and rear control arms, struts, and sub-frame connectors allowed.
    Street Equipment:
    Headlights and tail lights required one headlight can be removed for induction.
    Windows:
    Lexan permitted
    Interior:
    Dasboard required.
    Exhaust:
    Transmission:Any type transmission allowed.
    Electronics: Delay boxes, Prohibited
    Tires:
    FWD:28x10.5
    AWD 28x10.5
    RWD 28x10.5w
    Clutch/Shifter:
    Clutch must be manually operated, shifter must be H pattern, air/eclectronic shifters prohibited!
    Driveline:
    Payouts: $3,500
    DSM Whore gastroker's Avatar
    Newnan
    Well, unfortunately I just found out I'm going to have to work that Saturday. My boss is going out of town so I have no choice. Damn it.
    Northwest Georgia
    pwned, im going to try and go, i got owned by the head stud holes at a bad time...so i wont even get tuned until this coming week sometime....so i got one shot for testing before i decide if im going.
    South Side ATL
    Hmm 3k....The Rx3 will have to make another showing... I hope the track is ready for 7sec. passes. I cant wait to see the turn out, I was almost getting bored with straight line 1320.
    Northwest Georgia
    not looking good for me now....unless miracles happen by next friday. lol. Damn electrical parts.
    Southern Speed
    Macon
    what happened?
    Northwest Georgia
    e85 gummed my injectors shut, apparently you are supposed to purge them before they sit for a while when running e85, and i didnt. Well ive learned my lesson for next time.
    The event is only a couple days away!!
    Checkout HI-Boost 1.9 as they get ready to Run Pro Mod Todd's 9Second Toyota MR2 on September 11tth SICC Drag Race and Car Show at Fayetteville Motorsports Park!!!
    http://www.youtube.com/watch?v=9UUr3YScPSM
    Click this link below to download and watch the video in high quality!!!
    http://nyce1s.com/MISC/Dyno Videos/2...s Sept. 11.wmv
    Checkout the information below for the Upcoming Nyce1s.com SICC Drag Race and Car Show being held on Saturday September 11th, 2010 @ Fayetteville Motorsports Park!!!
    Privateer Racing!!
    Duluth,Ga
    I would love to go, But im working this weekend.
