Results 1 to 32 of 32
Thread: Here's my daily Z..
    more wood than noahs arc sirkus's Avatar
    Cartersville, Ga
    Default Here's my daily Z..
    Figured I would introduce myself.
    It's a 1976 280z 4spd. It is bone stock, other than the headlights and wheels. I believe it has around 220k miles. (reading through the maintenance records).
    I recently bought this car from Zakalicous.. and I've been driving it daily since.
    The first plans for it is to get the body in perfect condition. It has very minimal rust (a few little surface spots here and there). I am saving right now for the primer/paint/clear and after that maybe a swap. Although I was thinking about keeping the stock engine in it and do a mild build on it.. but a 1jz/2j just seems too sweet.
    But anyways.. here's the pics. Hope to see some of you guys around.
    (and I'm no pro photographer.. lol It's always point and click)
    2014 | Hyundai Veloster | Turbo R-Spec
    Where Am I
    That thing looks really clean man....
    Super clean car. Good stuff.
    I've owned numerous Z's. The most fun i've had was with a small block Chevy. I've had a 306 Ford, 350 stock, 383 Stroker and an RB25. The MOST fun was the 383 Stroker. I would personally leave the L28 in it until it shit the bed. I liked my stock 260 motor in my white one, that's why the car went from that to the 306, then back to the stock one, then to a small block 350, then back to the stock one...then to the RB25. Stock motors can be fun man.
    Garage-Sixgun
    Beautiful car, man. I love it, but...
    Quote Originally Posted by sirkus View Post
    You have a Datsun. Not a Toyota, lolol. Later, QD.
    Niice ride it's really clean and I love the tag haha
    Cartersville, Ga
    Thanks man..
    I'd much rather have a L28et or a RB25 in it. I'd also like to keep it in the Datsun/Nissan family. It's really a money/power issue when it comes to me and the 1j/2j.
    I know I would also enjoy the 350 swap.. but I don't want to slaughter the car. The more original it can look and sound, the better. I can't have a fuel cell hanging from under the car and have people expect to to be in the least bit stock.
    Vinings, GA
    I approve
    Lol. My 383 car that I just let go of ran stock tank, 5 speed swap, no butchering. The only difference in mine was that the trans sat a little to the passenger side of the tunnel so that the center console didn't fit quite right. You can drum down the mufflers, run A/C on it if your car came with it and it will be enjoyable specially if you don't go to radical with it.
    My advice, RB25 swap. Straightforward swap, you can get the motor and a 20 trans on the cheap, and it makes decent enough power for a car to drive daily. L28T....never put much faith in them for some reason. Plus with the RB, you get the straight 6 howl in the exhaust.
    Garage-Sixgun
    Cartersville, Ga
    Quote Originally Posted by Glides View Post
    Drum down the exhaust? Lol.. It'll still sound like a salty little pisser. I am leaning more toward the RB swap now. After reading some specs, and actually trying to call around for prices. I can find them for less than a 2j and about the same price as a 1j with a 5spd. Stock they seem to put out a good bit of power. In a car that sits around the 2300lb range, it would be some very fun power. I think something such as a 383 would be a bit of over kill. Looks good, sounds great.. but I would go through back tires like a bulimic fat girl with a wedding cake.
    So I can still run my stock tank with a v8/rb25 swap? Why do so many people go to fuel cells? Rusted out or something? I dropped the tank about a week ago to see if I could fix my gas gauge and I was surprised to see no rust. I was also surprised to see that someone had wire nuts on the wiring to the sending unit.. which wasn't holding.. apparently. I guess that's the fun part with a car that's 34 years old.
    The car originally come with A/C and all of the parts are there.. but several hoses are dry rotted and it won't charge. It will need all new hoses and seals. It just blows my mind that so many people do swaps and don't keep things like A/C if they can. I always assumed that most swaps don't include A/C because of cost, but it seems to be well worth it.
    Are there any benefits going with the R34 neo6 RB? Or should I just stick with the blacktop r33 RB?
    Cartersville, Ga
    Quote Originally Posted by Turbodude06 View Post
    Thanks man! I sold the Accord to get this.
    Quote Originally Posted by JessAlba452 View Post
    Thanks I didn't know what else to get. I tried to get WTF RLY.. but I got a notice in the mail saying that it was rejected. Figured it wouldn't have made it that far though.
    Quote Originally Posted by NewGen33 View Post
    I approve
    Thanks man.. you have a pretty sweet Z too.
    Nope, you can make that thing quiet as a mouse if you want, you will sacrifice some power, but you can do it.
    A 383 is overkill, but suprisingly, it hooked up pretty decently. You of course could get the rear end loose as a goose, but if you wanted control, you could get it very easily.
    I would do the RB25 and i'll tell you why. A. It's Nissan, B. it's decent in stock config (as you said), C. it's pretty common and D. it's mostly stock. You can go with a Neo6, but why? Stick with a 25 with a decent turbo and use the computer. It's balls simple to install and since it's stock, it's plug and play. Install and drive. No tuning, no tweaking...nothing. The hardest thing will be the driveshaft and that is as easy as measuring and taking it to the driveshaft shop.
    The A/C is the biggest downfall of most swaps. When I was young, I took A/C off of everything simply because I was stupid and thought that the minute savings I received would somehow translate to blistering speed on the street. Now, I don't want a car without it. The Galant I just got is on it's way to getting the A/C back on it. Rerouting the intercooler piping if need be, whatever it takes to get it back on there, that is if I keep it. So for me, any swap needs to have it. To do a swap on a factory A/C car and not hook it up is fucking stupid. Pay the little bit extra and get it hooked up.
    You have a great start.
    Garage-Sixgun
    cVon Photographics cVon128's Avatar
    Centre, Alabama
    Nice car man! Glad to see people rocking the old school Z's. I plan on getting a 280 soon and building the L28. I also have good resources on rotaries and probably will eventually do a 20b in one. The engine bay in those cars will hold nearly any engine with the right setup. I have seen alot of people doing LS v8's but I'm a fan of sticking to brand (or country lol because a 2j would be nice too). Good luck with your build and post some pics when it's finished!
    See the new official poster for "RX'79", an upcoming short film and photo feature from cVon Photographic Design at:
    http://www.flickr.com/photos/srfh/5881644161
    Cartersville, Ga
    Thanks man.. A/C will def be in this cars future. I will be going with the rb25 swap. Considering it's support and power specs it seems to be the best candidate for the 280.
    I was wondering.. all of the bushings and stuff for the front/rear end are shot is this car. Next time I jack it up I will get a photo to express how I mean "SHOT". I do not understand how this car keeps the steering straight as I'm going down the road. I believe every bit from the shock/springs/bushings and even rear diff oil has NEVER been changed. I'm going to check around for master bushing kits for it.. considering Nissan quoted me 431.81 for just all of the rear bushings (I got a quote when we took the cube for it's exploding fuel tank recall) which I though was ridiculous. I bought a set for an 82 camaro z28 and it run me around the 100$ range about 8 years ago lol. It needs them bad. Has a small clunk in the rear when you push on the throttle. It has lead me to believe it's either tranny mounts or rear mounts.. but after looking at them all.. GOOD GOD they all need to be changed. I might be tackling this issue before paint.
    I also noticed I have a small coolant leak starting. It's most likely a dry rotted hose.. but I shall further investigate.
    Cartersville, Ga
    Quote Originally Posted by cVon128 View Post
    The 20b is a beast.. I wish to god I could have put one in my old 90 vert. I've had 3 rx7's and I've loved them all. I would have kept the vert if someone hadn't of offered me a SI with a b18c5 swap. I've had a 85 with a 13b, after I sold it I bought an 87 GXL. After it was totaled I moved on to the supra's and stuff. But a few years ago I picked up the 90 Vert that was 100% stock. Still had the factory BBS's on it. I did a couple mods to it to make it look good (JDM FTP lenses, tinted windows 15%, new tires) and then someone offered me a trade I couldn't refuse.
    But thanks a lot.. The 2jz is always screaming my name. But after much research that rb25 is the leader of the pack. I will use this as my build thread. Any and all mods that I do will be in this thread from no on.
    OMG! It's Dylan! qwick's Avatar
    Milledgeville
    I love these cars, but i just dont have what it takes to buy one and maintain it lol.
    looks good man.
    Haha nice to see my old car has changed hands so many times, also the milage isnt even 100k yet, just letting you know
    Nissan by Nature LeX's Avatar
    here
    I still need to check it out dude lmk what day you're not working
    72 Datsun 510 goon SR
    83 Datsun Maxima RB
    80 Toyota Cressida 4M
    jack daniels addict integra938's Avatar
    marietta
    I LOVE IT
    Feb 2010
    wait.. Glides you ALREADY got rid of the 383 Z?!?
    Cartersville, Ga
    Quote Originally Posted by LeX View Post
    I might be off saturday and sunday.. I will text you with my new number..
    Quote Originally Posted by integra938 View Post
    I LOVE IT
    Thanks Trade ya z's
    Quote Originally Posted by TheTrott View Post
    Did you ever register it in GA? I had the lady at the tag office check past owners and she said there was 3.. I become the 4th, but it was last registered in Tennessee. I had to have the cops come and check vin#'s to verify it wasn't stolen. I know the guy I got it from never registered it. So I'm not sure whats going on there. You do anything to it?
    Quote Originally Posted by TheVengeance View Post
    Lol same thing I said..
    Lol yeap....gone baby gone. I move fast on shit brother.
    Garage-Sixgun
    Feb 2010
    you really are outta your coconut my man.. you really are gone..
    Who it is!® zakkkaliscious's Avatar
    kennesaw
    glad you are enjoying it, i miss that car. no i never registered it. sorry if that caused you any issues.
    Haha I know it,....but only on Thursdays man.
    Garage-Sixgun
    Yeah i registered it for an entire year with a tag and everything, the only mods were the headlights and wheels, the seats cost a small fortune, the car runs perfect plus it was always maintained, great dd wish i didnt have to have sold it
    Oct 2009
    kennesaw
    pretty clean car to be old..nice
    pwnage
    I agree with Glides, enjoy the L28. I converted mine to carb because I was having issue with fuel/vapor lock during the winter. Get MSA header, 2.5 pipe to a free flowing muffler with no cat. That thing fucking roar! The L28 open up sounds fucking addicting as hell. I'm the bastard that screamed down I-75 around midnight on the weekend, waking up everybody. I will drive that motor till it blows up then start thinking about motor swap. Really glad to see people putting love into the S30 again. I'm only 26 so the people I tend to see with that car are double my age hahah. Would be glad to see your ride.
    Unknown
    Dec 2008
    Z cars represent!!!
    South Side ATL
    I was wondering who was going to finally buy that thing, little rough but has major class and poten. I have the GUN Metal carbon fiber 240z with RB25det big turbo 5**hp, If anyone is to tell you the in's and out's of the rb swap I think I would be of some help. I may have some parts you could use if you were interested then pm me. Im an OverKill guy so I say pull that old motor out and place it in a bubble...put a newer heartplant in and beat the hell out of some pavement. The Power to Weight Ratio alone is far above any Super Car you could buy for 100K. The old motor is for history buff's that wanna put the car in the old folks retirement home and bring it out for parades....Brotha when driving a Z with 400 - 5plus Viagra would be candy compared to the fun you will have.
    Stay Humble
    WV
    i love these cars !
    Rocking out in straight pickup status lol
    IA Member dilbeckskate's Avatar
    Feb 2011
    Jasper Ga
    great looking Z man, allways loved those things
    1990 Honda CRX Si (sold)
    1991 Honda Hatchback Si (sold)
    1985 Toyota Corolla GT-S
    ^FTW
    hi, beautiful car, minus the 1jz part =) If anything, stick with the RB series and stay Nissan all the way.
    If you want a good paint job, a great guy, and an experienced person who has done many old school vehicles, and relatively inexpensive, then I have the right person for you. My good friend Chris Allen has been in his business for over 15 years and a few of my friends had used him as well and have been very happy with his work. He just recently finished my 1973 RX-3 and did a fantastic job, and is currently working on my friends 1975 bmw 2002!
    Here is a picture of my car @ Import Alliance. If you have further questions or want to know more about paint and what not, please email me @ [email protected]
    Regards,
    Marco
