Thread: BEST!! Way to polish my blades?????
    IA Member CodeRED-MVBC's Avatar
    On a train, In a plane!
    Default BEST!! Way to polish my blades?????
    As it states, whats the best way to polish my blades?? I plan to prussure wash them, and see where that leaves me. Any hapl is useful!!!
    Peace
    "VTAKS- just like boost with none of the lag...and none of the torque...and none of the boost "
    Oct 2009
    Warner Robins, GA
    if your looking for a quick way to get it done, I would bead blast them then start from 600 grit and work your way up to 2000. only problem with this method is that you may end up with tiny pits in them from the blasting. As long as you keep the gun far enough back from the wheel, you should be ok. But of course this will only work if you have access to a bead or sand blaster
    I had a really nice, detailed write-up on here with pictures, that I spent about an hour or so writing up... and someone completely deleted it.
    JohnBobAlingAdang 88NaCivic's Avatar
    Walton Cnty
    Dont rush this job, if you do they will never look good! Take your time. Start with a lower grtit go 400 first
    thanks!! i poszted this a minute ago.. tryin to get a type sh lude.. sure after they get straight they'll be on here for sale!!!! But im scared to take sand paper to them.. no access to a sand blaster for me.. Ww in the boon docks!!! Thamks for all help you'll!!
