Results 1 to 19 of 19
Thread: 94 integra not getting spark?
    Norcross
    Default 94 integra not getting spark?
    hey i just did a obd1 LS swap into my integra and im not getting spark now. I got the dizzy from my friend and he said it came off his DA integra and was working when he pulled it. But when i use it its not working? The car cranks, but just wont turn over. I also touched the starter and it gets kinda hot. Could it be any of those? or maybe an ignition thing.. i did change the steering column and maybe didnt connect a plug?
    please help asap IA. +reps for help. thanks.
    del sol? 94_teg_ls's Avatar
    main relay kicking on?
    /sig
    relay or try another distributor to see if it works. just to let you know don't try starting the vehicle more than 15 sec or else it would damage your starter. most likely when your not getting spark it will be your icm inside your distributor, just replace that and see if you have any sparks.
    Titties!!!
    Quote Originally Posted by jdmalltheway View Post
    i have a couple of these that work that will fit. check also to make sure there is no oil in the dizzy. if it came off a DA is everything wired right on the dizzy. also make sure the firing order is right.
    Norcross
    made sure the firing order is right and i also just went out and bought a brand new dizzy, and STILL NO SPARK!. i checked the main relay also. im running out of ideas
    K-BLAM! KIZDAWAY's Avatar
    atlanta
    VTC not working
    Norcross
    well now i found out that im not getting spark and no fuel is reaching the cylinders. helpppppppppppp
    ecu?
    /sig
    Norcross
    tried my friends ecu and still doesnt turn over
    check you t stat housing ground
    /sig
    Norcross
    thats good, already grounded, all grounds are good.
    ok then is the fuel pump turning on?
    /sig
    Norcross
    yes it turns on, and is loud as hell. getting fuel to the fuel rail, but not into the cylinders?
    what injectors?
    /sig
    Norcross
    obd1 rc 650 rcc high impedience
    you have stock one i would switch them out
    /sig
    Norcross
    im not sure if my basemap will let it crank, cause the basemap is set for my injectors, 650
    use stock ecu, stock injectors and check timing
    /Oo ___A___ oO\
    |=_/_______\_=|
    Greene/Athens
    Check injector pulse just to see?
