Results 1 to 4 of 4
Thread: << sohc cam over headin need help >>
    your moms house
    Default << sohc cam over headin need help >>
    ok this is the thing my car just started overheating since i supercharged it it already blew two of my water hose idk why but sometimes is ok sometimes it gets really hot guys tell me it could be the thermostast some the temp bulb ??? what should i do need help
    (((((No more 4 door))))))
    barrow county
    boost means more heat. does it over heat after hose blow? or before?
    could be stretched head bolt(s) letting air/fuel entering cooling system untill it fines a weak spot ( hose )
    again could be many things. more info
    That sounds like a headgasket. Did you get it tuned after you put the supercharger on it?
    Unknown
    Jul 2010
    ga
    boosting it means more heat thay r right i would reserfus the head and put new gasket and the get bigger raidater to pervent it from overhrating agane and yes sometime a head gaskit will let it run hot sometime and sometime it wont been there done that sorry for your luck bro need help hit me back
