Results 1 to 11 of 11
Thread: T Bracket
    Jan 2010
    Macon
    Default T Bracket
    Ok i am doing a b series swap in my 1998 Civic and i was woundering is a auto t bracket the same as a manual?
    a/c and hid crew member #2
    Smyrna
    No. You will need the T Bracket from a 99/00 Civic Si to mount the swap properly. You might be able to find one at Honda Parts Connection or just go through Honda. I got mine for $95 3 years ago and it took 1 day.
    98 EJ8 - Stolen ( Thieves)
    Jan 2010
    Macon
    Ok will a dc2 rear t bracket work?
    Smyrna
    No. Only the one from the Si will work for the 96-00 Civics. Integra Bracket is too long for these year Civics.
    your moms house
    yes it would
    (((((No more 4 door))))))
    Smyrna
    yes it would
    The Integra T Bracket won't work on 96-00 Civics. It will only work on 92-95 Civics. The only way to consider using the Integra T Bracket would involve consdierable modification/welding to fit. If you try to use the Integra T Bracket in a 96-00 Civic, it will push the Engine/Tranny too far forward and it won't line up with any other mounts. This comes from personal experience swapping a LS/VTEC into my 98 Civic EX Coupe in 2007. You can try all you want with the Integra bracket and you will be right where you were before, an unfinished swap. By that time, you would be better off buying the Si one from someone or Honda.
    Jan 2010
    Macon
    Ok thanks
    Quote Originally Posted by bafbrian View Post
    co sign
    aye Harold, i still say my car faster than yours
    no its different
    Jan 2010
    Macon
    ok thank u guys for that, I went to the honda dealer and bought a si T bracket and it fit perfect.
