Thread: 95 civic a/c problem....kinda weird help
    Default 95 civic a/c problem....kinda weird help
    i might be havn eletrical issues idk, my compressor is cut'n on an off but this seems to happen only when the car sits in the sun for a while, now while im drive'n i can hold down the RECIRCULATE button down the compressor will cut on an run until i let off the button, now if the car has been in the shade this doesnt happen
    now i hav other small issues i havnt had time to trouble shoot they may be link'd together idk so im gonna tell yall incase it helps figure this weird shit out, i had to run starter off button from battery cuz the starter signal wire wasnt getn enough voltage, the ignition doesnt beep unless u push key in (but i just fig that was old honda think my others did that too) i cant think of anything else
    i hope i hav giv'n enough info for yall to help or som1 has had this isssue before
    thanks IA
    aye bro .:Stirfry:.'s Avatar
    check the high pressure switch it can either be that, one way by checkin if the clutch on the comp is kickin on, crank the car and turn the ac on and if the clutch doesnt kick on unplug the high pressure switch and jump it with a wire or paper clip and if the clutch kicks on its either low on freeon, and not letting it build enough head pressure, or you have to much freeon and its buildin to much head pressure preventing the clutch from kicking on.
    or you might just have a bad pressure switch. could be several things hope this helps a lil
    ATL DAsquad Member #9
    Stang Mod slostang's Avatar
    Southside
    Have you hooked it up to a set of gauges?
    awesome i will check the presure switches
    yes ive put gauges to it, i just charged the system it has i think 40-50psi
    ttt, still need help trouble shootn the high preas lines an switch 2nite, but idk i hope its som'n simple like that, but any1 else who has any ideas feel free to giv em' up
    romex slinger
    jefferson GA
    need a full wire diagram for the a/c?
