Thread: d16z6 not starting!!!!!!!!!!!
    Default d16z6 not starting!!!!!!!!!!!
    ok so i have tried to search this problem more times then i can count. a buddy of mine bought a 93 si hatch that had been sitting for about 2 years. the car wouldnt start the first day but after messing with some fuses it started. the car was driven for maybe a day or 2. he starts it up one morning to let it warm up before he drives to work and as its warming it shuts off. the car wouldnt start after that. after changing the dizzy, coil, plugs, wires, cap, and rotor with all new parts still nothing. today he removed the fuel rail to see if the injectors were working and he got nothing. the pump is priming so he removed one injectors and fuel was shooting out of the hole. what would make the injectors not work? any help would be great.
    barrow county
    did you change the gas? old gas can clog injectors.
    if all that was done and your 100% sure injectors are good and its getting fuel but its not going through the injectors than ecu isnt sending signal.
    try swaping the ecu
    try swaping the ecu
    the car was on E so there wasnt much gas to get out. 93 was added. im sure all of that was done and i forgot that we tried another ecu and it didnt work.
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    it might be the CKP sensor. check fuel pressure at the fuel filter
    98 Acura Integra LS-DD
    ??????????????????-project
    give me a call i got a few easy diags i can do.
    hey i gave my buddy your number and he should be calling you if he hasnt already. thanks man.
