Results 1 to 11 of 11
Thread: VICTOR X OR SKUNK2 PRO SERIES?
    Jun 2010
    land down under!
    Default VICTOR X OR SKUNK2 PRO SERIES?
    i have a semi built itr motor an i want to know if the victor x manifold is better then the skunk2 cause im going to buy one. those any know witch one will be better for my motor.
    my motor is bored .20 over an has 11:5 comp! stock value train. thanx for yall's help. im am not using the baby bottle or boost. all motor!
    Southside Ridin HATCH
    sup bro.. I know who this is!!! HAHAHAHAHAHAAHHAHAHAHA
    Anyways.. the Victor X would be better if your getting some bigger cams, throttle body.. And if your compression was a bit higher like..ummm...well you know who!
    South Side Georgia
    for you setup use S2 manifold..
    resize pic
    time for the build! jerseyef9's Avatar
    SOUTHSIDE
    with that set up you need to get performance x mani fold son
    R.I.P Booga
    M.A.P
    F.D.L.R
    IS300 NEMO's Avatar
    We Fuckin...
    isnt the stock type r manifold about the same as the S2
    SOUTHSIDE
    nemo you exactly right performance x is perfect if you like b20v then a victor x would work perfectly
    R.I.P Booga
    M.A.P
    F.D.L.R
    your moms house
    the performer x makes more power on engines with cams and supporting mods i've seen the dyno to prove it.
    the skunk2 does good but if you planning on some more mods later down the road go ahead and pick up the perfromer x and be done with it. the skunk2 also fits and looks better but the perfromer x makes more power but needs some cleanup in the ports and such because of core shifting when making them but thats nothing a dremel can't fix.
    Jun 2010
    land down under!
    Quote Originally Posted by all-mota View Post
    thanx for the info i guess i know which one two get.
    your moms house
    no problem
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    That manifold is for turbo cars..... just sayin' :smh:
    Like what all-mota said, get a performer x
    SOUTHERN SPEED
    macon ga
    lol what he said performer x if your going big as for right now the skunk2 will more then support the air you need . The victor x is for turbo maybe around 260hp you might could run it all motor but would still kill air speed its made for a turbo.
    252plus hp and 34.5 miles to the gallon all motor. 12.2 at 111
