Thread: Purchasing advice
    Eurotrash
    Sep 2009
    in my own little world
    Default Purchasing advice
    I'm looking at a 93 325Is. Just curious as to some common problems with these cars and what to look for other than the obvious. Thanks in advance.
    Eurotrash
    Sep 2009
    Nothing? I know out of all the BMW owner's on here, someone has some input.
    Deuce Deuce BB1_Luda's Avatar
    Cooling system, Mainly.
    All the hoses and fans.
    Those are known to wear out and leak.
    Thats all that I know of. Other than that they are very solid fun cars.
    Eurotrash
    Sep 2009
    Thanks man. I'm hoping its a solid car.
    DSM driver
    Buford
    check the shifter bushings if it is a 5spd
    check the clutch fan and the aux fan for play
    check the sunroof for functionality
    the blower motor (ac) at all speeds
    make sure the rear trailing arm bushings are good
    the lower control arm bushings as well
    check the guibo(flex disk)
    check the expansion tank sitting on the side of the radiator for leaks coming from anywhere especially the bleeder screw on top of it
    if it is a car with vanos, listen to the vanos for any wierd noises
    check the return line for the power steering
    check the intake boot elbow for any cracks
    check the tail lights if one is blown actually take the bulb out and look at the socket on the tail light assembly
    if it has digital AC check the capacitor inside by turning up the interior lights all the way and see if the ac unit lights flicker
    check the OBC for dead pixels
    make sure the valve cover and vanos solenoid are not leaking any oil
    PM me when you go to check one out and ill go with you if i am available there is alot to look for
    03 CBR 600 F4i
    96 E36 Frankenstein
