Results 1 to 4 of 4
Thread: A Minty Fresh, in the Plastic GSR head
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    Default A Minty Fresh, in the Plastic GSR head
    Contact: email at [email protected]
    Item: GSR head w/ thermal intake manifold gasket
    Price: $600shipped (price is negotiable)
    Up for sale is my minty, still in the plastic GSR head. This head is fresh out of the machine shop, and is ready to be bolted onto your motor. I purchase this GSR head from a person on IA to put on my b16, but it ended having 4 bent valves (Yeah, that's gay as hell I know). So, I had those valves replaced, and while getting that done the head was cleaned, resurfaced, and received a 3 angle valve job in the process. All of this has been documented, and I have a receipt to prove it. In addition, I had ITR exhaust valve springs installed on the head so both the intake and exhaust can have dual valve springs. This setup should be able to handle Type R and most stage 1 cams.
    Finally opening the plastic
    Look how clean the intake ports are
    And how clean the exhaust ports are
    The thermal intake manifold gasket
    This head comes with the following:
    -head
    -matching cam caps (w/bolts)
    -VTEC solenoid
    -thermal intake manifold
    -exhaust manifold gasket
    -b17 cams
    -piece of mind knowing that you just purchased a great head with no problems
    Not included
    -valve cover
    -intake manifold
    -dizzy
    -problems
    Some people may think that this head is overpriced... cool. But you have to realize this isn't your "My motor is knocking, it jumped timing 5 times, so I'm parting out my motor" head, or "I don't know much about this head" head. This head has been pressured check for leaks, completely disassembled and reassembled by professionals, and received a valve job in the process (which was close to my asking price). With that being said, if you're interested contact me by email
