Thread: FS: S13/S14 Cusco 2-Way Diff
    is better than you..
    Somewhere you're not
    Default FS: S13/S14 Cusco 2-Way Diff
    solddddddddddd
    Senior Member Capt._Ron's Avatar
    Canton
    which pumpkin is it in? It may require adapter bushings depending on the model its going in.
    Its in a JDM 180sx VLSD housing
    Around metro-ATLANTA & IA!!
    hey what did this come off of? i got a 96 S14 with no LSD...is this a direct bolt on?? lmk thanks
    Canton
    Quote Originally Posted by LongLiveH2b View Post
    Just from the part of the picture I can see it appears to be a direct bolt on for an USDM S14 based on the size and positioning of the bolt holes towards the front of the pumpkin. I can't be sure though. To install a S14 diff in a S13 in know you need bushings and longer bolts to reach the subframe.
