Results 1 to 40 of 45
Thread: THINKING ABOUT A H22A EG/EK HATCH...
    Default THINKING ABOUT A H22A EG/EK HATCH...
    i have a ek coupe with a jdm b16a and its just not fast enough...i'm thinking about buying a hatch shell and getting a jdm h22a(prelude type s, 220hp, 163lbs) to drop in there. has anybody had this done or know anybody who has? any problems? any opinions? i just want all that tourqe! and 220hp stock! plus the change over from h motors is $1000 cheaper than the b18c5 change over and not that much more to get the swap done. whatcha think?
    The only problem w/ the h motors is the size and weight. I wouldnt suggest it unless you do mostly drag racing, at least from what ive heard it makes the car harder to handle cuz of the extra weight over the front wheels but i have no experience to say whether this is true or not. It takes a little more work to get in, but its been done multiple times so you can buy mounts and everything else for the swap and find out everything needed. It would definitly make a fun quick car so good luck w/ it if you try it. I believe there are a couple of them on this site actually.
    On a side note: didnt u just get that b16 in ur car or am i thinking of somebody else? If you want some more power why dont you just boost it, you could get 250 whp and have more torque than an h22 w/ ease, plus it would be less hassle.
    I thought about going for that swap for a long time, but like mentioned before handilng will be less that usual...
    hey but if you want to sell that B16 swap ill buy it...lol
    yeah i did just put that b16 in my car and i love my car...but my father has a used car lot out here in conyers and hes in texas right now at theese huge auctions he goes to every month and i talked to him and he said hes seeing eg and ek hatchs for the low low going across with alot of miles and nobody bidding too high on them and that got me thinking...small light weight car for real cheap + alot of power = what i really want. plus my car is more of a show car, i got shaved door handles and my bestfriend goes out to alabama every month to run the road course and i can't run cause of shaved door handles. i might buy a hatch and it might sit at my dads house for a few months and when i get the money start working on it.
    Little Red Ridin Hood
    In My House
    H-Series are not that much heavier than B Series.
    i think it was somewhere from 50lbs plus or minus.
    In My House
    H-T Info:
    H = 123lb short block
    B = 104lb short block
    D = 100lb short block + oil pan
    So with totaly fair comparisons... the H is 19lb heavier in the short block.
    NOW lets move on... the big word that I always hear is that its the H TRANS IS SOOOO HEAVY!!! Lets take a little peak here...
    H trans = 96lb
    B trans = 90lb
    things that make you go ummm
    Super Ghetto Rally Team EP3sAreFun's Avatar
    Barrows
    theres more than weight to do with this... its called physics... the engine in that spot shifts the center of gravity lower and more front along with doing a bunch of other things... making understeer even worse... suspensoin setups can help counter act this
    with axels and everything... the way the car flexes and bends alot of things you need to think about other than just the motor and power
    just some things to think about. do some searching on this.
    Mine really dosn't leave the garage. People across the street think it is a tool bench.
    The most common Honda misconception ever!
    H trans = 96lb
    B trans = 90lb
    The fully assembled H series head is about 10 lbs heavier than a B-series totaling 35lbs more
    A complete H-series will run $1,800 or so with another $500-1000+ to install.
    I know where a 280whp H22 is just begging to go into a car but you can't get it for that price
    Quote Originally Posted by R-81 Eee Gee
    H-T Info:
    H trans = 96lb
    B trans = 90lb
    lol, fucker....helps if i read all the posts first
    Emergency Medical Tech
    Oct 2003
    Duluth,Ga
    My question will be why do u want to go with the type-s when u can buy the normal h22 and make it faster for a lot chaper?
    You don't know how STRONG you are until being strong is the only
    CHOICE you have!
    'Born Ready!',LJ
    DC5-R
    Gwinett
    Quote Originally Posted by ruah_23
    the type-s and the euro R motor is about the same thing, good for the money in other words, but putting it in a hatch is a little more difficult than you think, its just not power on demand its also the power to weight ratio or physics like stated above. In my opinion you should just keep the B16 and build it.
    Duluth, G-nett
    or go type r man. seen a couple of hatches with h22's and they complain bout traction.
    Oct 2003
    Duluth,Ga
    Quote Originally Posted by krucial7integra
    the type-s and the euro R motor is about the same thing, good for the money in other words .
    How's it good at the money. H22 type s cost 3600 complete swap while the jdm h22 cost 2199. With that extra money u can buy a turbo kit and go much more faster than the type s. Besides that,there's also an issue abt parts availabilty.The only thing good abt that motor is that it can rev higher than the regular h22, and in that case, if u want a high reving motor, B series will be a good choice.
    CHOICE you have!
    'Born Ready!',LJ
    i was looking at the jdm type s on h-motors. but you people freaking me out with all this talk about not having a car that will handle like i want it to, i can't live with that. i would want to take it to the track (road) and handling is just as important as power in that situation. yeah i thought about just dropping serious cash into the car i have now. like i said i'm not for sure yet i'm gonna go with this but i'm seriously thinking about it. i've put so much money in my ek coupe theese past couple months and there no way in hell i'm gonna get out of it what i put in it. when i bought the car it all ready had the champ white, body work and swap. since then i've replaced the motor, exedy cluth and fidanza fly, suspension work, cv axels, tires...and on and on and on.
    if i do go with the hatch though since i really can't afford type r i'll go with sir-g with a mild build and eventully an jackson racing supercharger( that take awhile though $$$$)
    Oct 2003
    Duluth,Ga
    U can always put a roll cage...
    CHOICE you have!
    'Born Ready!',LJ
    In My House
    im sorry... let me take my post out =P
    West palm beach
    stay away from this swap,its a waste of time and money,you can do a ls/vtec and make more power and weigh less............
    NO ADVERTISING
    -IA MANAGEMENT
    Oct 2003
    Duluth,Ga
    Quote Originally Posted by punkr6
    How's it a waste of time and money?
    Give me reasons to backup ur thesis.
    CHOICE you have!
    'Born Ready!',LJ
    you can make more than 220 with an LS/VTEC for the same price as an H22 ($1,800-2,500)? How much would have to be spent to make an LS/VTEC put out that much?
    superduper LLLLLLLLL
    Quote Originally Posted by 95boostedteg
    I think i'm one of the guys he's talking about.
    we built an H22 EK hatch for my girlfriend.. she loves it
    it does have traction problems when launching.. but nothing some drag radials or slicks can't fix
    h22's are actually only like 30 lbs heavier than a B-series motor..
    it doesn't seem to affect me too much.. just go on a diet for a week.. and it'll even out the weight for ya
    Quote Originally Posted by AnclyT
    Can't a little suspension tweaking fix most traction problems?
    ...ok off topic but this is bothering me:
    01' black bb6 prelude
    97' gunmetal ek9 hatch
    90' sr20det 240sx fastback
    is supposed to be...
    '01 black bb6 prelude
    '97 gunmetal ek9 hatch
    '90 sr20det 240sx fastback
    __DailyGrind
    i got a Eg shell if u ever need one...lol..
    DC5-R
    Gwinett
    Quote Originally Posted by VinhBodyS
    you got alot of things lying around, how bout gettin me a climate control for my teg.
    __DailyGrind
    i did have that..until that fuker 95boostedteg....took it away from me.....damn u ...but i got a Gauge cluster want that?
    Duluth, G-nett
    whats up with all the profanity? You on your period? lol
    i don't know if i went ls/vtec i'd spend abot the same amount of $ getting it built right as i would buying a b18c. i'd rather just go with a motor that was built for vtech rather than modifing it. i mean it does'nt sound like a bad idea if u got a ls teg but i would be buying a whole swap and i'd just be more comfrotable going with the sir-g b18c...thats just me though.
    Well i have a h22 hatch and yea when on stock springs it sucked a little..Now on omni power full coilover setup and some zenies it does really well.. I know this no bolt on b16 will touch it..My friend even has a ctr swap and its no race in the turns or straight...
    2009 zx10R
    2005 919
    2006 xt225 dual sport
    To 942JZGTE 93H22ACX's Avatar
    H22 hatch is fine..If you're going to go road racing you will upgrade suspension anyways so h22 hatch would be good. i personally love the H-series motor...
    I have had great success with the H22 motor and i doubt i'll ever go b-series just because of my own perferences.
    I know alot of H22 swapped civics dont run well but dont let it discourage you from getting it. you have to experience it for yourself and if you dont like it then go with the other motor...
    you really cant go wrong.... you want more power out of your B16? turbo or supercharge it.... maybe even squeeze....
    you want a h22 motor? swap it in and see if you like it... if not then go to a GSR.
    I dont think a LSVTEC will make more power than a H22. It doesnt weigh that much more and i dont think its a waste of money.
    My motor makes more than most Bseries guys on low boost (10psi=383whp and 323trq) and at say 26psi (615whp and 445trq), and my motor is a stock build....no p&p or anything... just sleeved with pistons.... and if you are saying you cant rev high... i rev mine up to 9500rpm every time i drive it. just needs a good build
    94 Supra= 500rwhp
    hey Bee....did you ever find out why your axle wasnt staying in?
    2009 zx10R
    2005 919
    Quote Originally Posted by Goinfasterthanu
    im 99% sure the lsd teeth is f'ed up... cause no matter what the axle will not snap into place... i had this axle combo for about 2 years and just recently had this problem. ill be dropping the tranny next week so i'll look at the lsd when i pull it out
    94 Supra= 500rwhp
    damn..that sucks.. Hope you get it fixed..BTW i like the coupe! How much more does it weigh?
    2009 zx10R
    2005 919
    thanks... not sure... but with my new 10 point cage im hoping for 2400lbs with me in it... my hatch and cage weighed 2310 with me in it.
    94 Supra= 500rwhp
    90 pounds is NOT BAD at all... does it seem to get out of the hole better?
    2009 zx10R
    2005 919
    DC5-R
    Gwinett
    yes I agree, thats not bad
    well i only got 1 partial run that barely made it through the 1/8th and it was my first run with this new car....
    but here's the difference:
    Times...............Hatch...............Coupe
    60ft................ 1.78's...............1.712
    330ft.............. 4.88's................4.715
    1/8 ET..........7.2'-7.3s...........7.1
    MPH................109mph...............103mph
    1/4ET..............10.6-10.8............11.2
    1/4MPH...........139mph................??????
    i still had about 1000+rpm left but broke. it broke around 8000-8500...
    94 Supra= 500rwhp
    VERY nice.... Im going to the track tonight...Im gonna try to preload the clutch..All i have is a 6 puck stg2 and light flywheel...Will it mess up the clutch? I just ask this cause staging at 6k with the clutch slipping sounds like clutch death..lol
    2009 zx10R
    2005 919
    DC5-R
    Gwinett
    man thats killer
    it wont mess up the clutch... but like all clutches... it will eventually go out. ACT 6puck is what i had last year before i got the twin disk.. it was a 1 year old 6puck clutch.... i ran it with nitrous and 24.5x8 slicks launching at 7000
    94 Supra= 500rwhp
